996 Forum 1999-2005
Coolant Temp Sensor Location
Old 05-16-2011, 08:14 PM
RPMulli
RPMulli's Avatar
Default Coolant Temp Sensor Location
I decided to buy a coolant temp sensor with my AOS. Where is the sensor located? I cant find it in the tech manual.
Old 05-16-2011, 08:25 PM
Barn996
Barn996's Avatar
For MY99 it's under the coolant tank, just about in the middle as I recall. Memory says it loosens by turning counter-clockwise.
Old 05-16-2011, 08:48 PM
RPMulli
RPMulli's Avatar
Is it mounted on the bottom of overflow reservoir or on the engine? I think the only sensor under the tank is the coolant level sensor.
Old 05-16-2011, 09:06 PM
RPMulli
RPMulli's Avatar
I think I found it... There is a sensor located right behind the passenger side exhaust tip on the block...
Old 05-16-2011, 10:04 PM
Barn996
Barn996's Avatar
My bad, I gave you the coolant level sensor.
Old 05-18-2011, 05:33 AM
xel996
xel996's Avatar
im confused
Old 05-18-2011, 07:09 AM
RPMulli
RPMulli's Avatar
Well... I must have ordered the wrong sensor. The one I found on the block looks identical but the shape of the plastic connector that attaches to the harness is different. Oh yes, I got the oil/coolant sensor for the 2002-2004 c2 and 996 turbo. anyone want a sensor?
Here it is... http://www.pelicanparts.com/cgi-bin/...C%20Each%20%20
Quick Reply: Coolant Temp Sensor Location
