996 Forum 1999-2005
Check Engine Drive - P0300 - P0305 - Misfire Error - Last İnformation And Questions:(
Old 04-13-2011, 10:02 AM
SS911
SS911's Avatar
Unhappy Check Engine Drive - P0300 - P0305 - Misfire Error - Last İnformation And Questions:(
Hi . My car 2003 996 911 CABRİOLET Carrera 4 Porsche
Firstly İ have a problem..
My car suddenly start to write check drive engine problem. and when its write
my car is making little a vibration. when i wait in the car.
I went to porsche service
they connect my car to the machine.
and machine says
5. cylinder problem there is problem air and fuel mix problem..
and they say my maybe this related to my bad fuel.
and they say you can continue to drive your car and you will finish your fuel.
and you will buy fuel another place. maybe this cant write again.
and they delete my error message.
i finish my fuel and i bought new depot of fuel. and i bought some fuel addition for cleaning
engine(injectors). and this didnt write again in 1 days. but after one days
it write sometime. and when it write check drive engine . my car making vibration more..
but ı continue drive my car because i think maybe its related to fuel quality and it can finish.
after 1 day when i waiting on the traffic lights it write again and when i want to
increase my speed my car dont go fastly.. i am try to increase my speed but car dont go speedly.
maybe 10 miles only. and my exhaust voice like bup bup bup bup bup bup its anormal voice. and i
am afraid i restart my car. there is no problem ... but i think this isnt something important . and i drive continue my car.
ı finish my depot and i bought another new fuel and some addition for engine.
this error write sometimes. maybe it cant write 1 days.
but when its write the vibration continue..
2 days after i am again waiting some traffic lights. my car write the error again and making vibration.
when i want to go fast. my car didnt go fast. i try to go 30 40 miles but my car is 10 miles.. and exhaust
make same voice bup bup bup bup bup bup like corvette . i am afraid i restart again and my car fix.
but i park my car under my home. and i am waiting. i will go to porsche service in 5 days.
i realised this is serious problem.
i want to ask you is there someone live this problem before.
or what do you thing this is important or not .
i am afraid of maybe it can make damage to my engine because there
is soo expensive the engines or something.
what do you think .
you are the bosses about porsches problem and i want to ask you before porsche service.
thank you for your replys..
good days
SS911
Old 04-13-2011, 10:20 AM
ivangene
Parts Specialist
ivangene's Avatar
sorry about your problem, there are SOOOO many things it "could be" and we cant hear the noises or drive the car so we all have to guess.....
my advise is to have it taken to the repair shop on a trailer and get it fixed... if its running poorly and throwing lights, dont drive it.
Old 04-13-2011, 10:50 AM
nick49
nick49's Avatar
I would try replacing the coils and spark plugs. This is a shot in the dark, but lacking any more details as to what the symtoms are, it would be my best guess. Most likely the cheapeast and easiest as well.
If your problem is a misfire, this will most likely correct it. This you could do yourself.
Old 04-13-2011, 11:23 AM
chsu74
chsu74's Avatar
Fuel filter. If you live in a place where bad fuel is common, then it may make sense to also replace the fuel filter ahead of schedule.
Old 04-13-2011, 11:27 AM
911SLOW
Admin
911SLOW's Avatar
Do you have the fault code(s) from the PIWIS scan?
Old 04-13-2011, 11:48 AM
philooo
philooo's Avatar
My Porsche tech told me that the 996 is very sensitive to bad fuel. I had problem starting mine when I filled it up at a gas station which obviously contained too much water (read condensation water). You can check my morning start problem on this video, sounded like everything was really bad but once fuel was replaced with good one, the problem never occurred again:
http://www.youtube.com/watch?v=2JYgW...er_profilepage
Difference with you is mine would not drive weird, the problem was only at start. Once the car would finally start, then it would drive normally.
Old 04-13-2011, 11:57 AM
Ubermensch
Ubermensch's Avatar
If you believe it's a fuel problem (water in the fuel) I suggest you pick up some "Dry Gas" or the equivalent to clean up the tank of gas you have. Cleaning agents for the fuel injectors likely won't resolve water in your fuel.
As Ivangene pointed out this could be caused by a whole host of different things but this is a quick easy thing to try.
Old 04-13-2011, 04:00 PM
ivangene
Parts Specialist
ivangene's Avatar
The coil pack sounds plausable
Old 04-13-2011, 04:18 PM
Macster
Macster's Avatar
Like others my best advice is to take the car to a qualified Porsche service facility and have the symptoms looked into.
Could be a particularly bad dose of gas and bad enough it has fouled the fuel filter. But it could be any number of things.
Be sure you insist all error codes read from the car are written down. Sometimes the error codes provide a clue as to what was going on.
Sincerely,
Macster.
Old 04-13-2011, 04:19 PM
jasper
jasper's Avatar
Spark plugs and coil packs it what it sounds like except that the dealer originally said the code was bad air/fuel.
if it's not the gas and not a contaminated fuel filter then maybe fuel injectors? That's not something we talk about a lot here.
Old 04-13-2011, 04:20 PM
jasper
jasper's Avatar
Sincerely,
Macster.
I was just wondering where Macster was. He's right of course - get the codes written down.
Old 04-14-2011, 02:55 PM
SS911
SS911's Avatar
Thankk youu for your all suggestions...
You are really interest my problem and i am happy about this.
I am trying to understand your writings completely ( because my english is bad )
But ı understand 100 % 80 of your writings. Okey i will make all of these things.
And i will take my car to porsche service.
Thankss again..
Old 04-14-2011, 03:24 PM
redridge
redridge's Avatar
When they read the codes make sure you write them down.... this will help diagnosing your problem.
Old 04-14-2011, 04:22 PM
Macster
Macster's Avatar
Thankss again..
Wish we could be of more help. But my concern with an engine running so poorly the less the engine is run until the problem is identified and fixed the better.
Even if one of us was able to come up the cause of the symptoms, almost certainly you'd still have to take the car to a professional/qualified repair tech and have the thing fixed. And he's going to want to make his own diagnosis. Which means he's going to want to run the engine. So the engine's run time when sick should be saved for this.
Please let us know the outcome.
BTW, how close are you to Kucukyali Is Merkezi B Block No:15 Maltepe, Istanbul? If you're ever in the area drop in and say 'hi' to Mr. Ozen at OzenElektronik from Marc @ Davis Instruments in Hayward, CA.
Sincerely,
Macster.
Old 04-22-2011, 04:43 PM
SS911
SS911's Avatar
I am in Antalya but if it continue. i must to go to İstanbul for better porsche service....
FIRSTLY
MY CAR gives me this error codes. P0300 - P0305 ( 5 cylinder ) ...
Porsche service firstly change the spark plugs place.
but 5 cylinder problem is not change. my car gives p0300 and p0305 error codes again.
if the problem in spark plugs maybe it gives to us the other number of cylinder.
after that services change the injection places. and if the number of cylinder change , the problem is injection. but my car gives same error code again. 5 cylinder..
so there is not problem too in injections..
and now my service want to take to pieces the my engine. because they cant found the problem now.
and they want to go into engine.but i know in antalya this service dont know something. and if they go into engine . it is very bad...
there is three choice ---------
1- i take my car and go to istanbul.
because i believe istanbul services has more experiences
2- i take my car and i am try to fix this problem with
the fuel additional something. ( i think its bullsht) I cant fix this way.
and last and trustable choice
3- i ask here. i say all of the things. i give error codes and information.
i think there is last chance for me . if you have suggestion to me i can give information
to antalya porsche service.
what do you think where is the problem .
Quick Reply: Check Engine Drive - P0300 - P0305 - Misfire Error - Last İnformation And Questions:(
