Rough Idle on Start Up
#32
Turning the key on and off didn't make a difference. Not sure what the air pump is?
It only lasts less than a minute.
I need to get a code reader. Maybe go to Autozone and use one of theirs.
Any pictures of where to plug it in? My car didn't come with a manual.
#34
#35
You don't spray the resistors to clean it. The sensor is actually at the bottom of the MAF. there's a thread on this board (can't remember which one unfortunately) that diagrams the airflow of the sensor and shows where you need to spray it out. If you look at the bottom of the MAF, you'll see a section that is like a "hook". It has an opening for the air to flow in. Look in there and you'll see the metallic sensor probe. The air flows past it and out a hole in the bottom. I sprayed cleaner on that and let it flow out the bottom hole. I did a couple 10-15 second shots. Let it dry at least 30 minutes. I'm still running fine and haven't put in the new one I bought. I figured I'd wait till it gives me the light again.
