996 Forum 1999-2005
NEW BATTERY INSTALL - Duralast 48-DL [autozone] March 2011
Old 03-06-2011, 06:47 PM
himself
himself's Avatar
Default NEW BATTERY INSTALL - Duralast 48-DL [autozone] March 2011
[cross post from GT3 forum]
Just installed a new battery. My old Moll OEM appeared to be from the middle of 2006, so it was almost 5 years old. I ended up going for the Autozone Duralast 48-DL, which was in stock for $92 [$104 without core].
48-DL is 4.5 lbs lighter and is identical fit.
Install was a breeze. 2/10.
1) Power to the car [probably don't need it but I used it anyway].
2) Unhook vent, battery terminals and mounting bracket at bottom of battery.
3) Slide battery towards passenger seat.
4) Tilt front of battery a bit and remove.
5) Put new battery in the middle/left of the tray, with just a little angle [they have a lip on the bottom that has to fit under a ridge.
6) Slide to driver's side of tray.
7) Reattach vent, terminal leads and bracket. I pulled out the adapter from the previous vent line and inserted the line into the hose that came with the battery.
8) Put cover back on and remove backup power source.
9) Good to go.
Old 03-06-2011, 09:06 PM
jyoteen
jyoteen's Avatar
you don't need to keep power to the car for the radio. I'm sure you know that.
Old 03-06-2011, 09:15 PM
himself
himself's Avatar
IIRC, after long enough the ECU loses power (need to reteach the car how to drive), clock loses power, the radio does as well. Plus, can't get into trunk/engine bay and no courtesy lights work.
If you don't have the radio code and haul the battery a long way, you need a trickle or a backup.
But I could simply be spreading old wive's tales.
-td
Old 03-06-2011, 09:19 PM
Barn996
Barn996's Avatar
Now you're good for another 5-6 years. Thanks.
Old 03-06-2011, 09:40 PM
Sneaky Pete
Sneaky Pete's Avatar
-td
Makes sense to me. The guys at AutoZone changed it for me right at the store in 5 minutes. Bought the same battery a month ago but I think it was closer to $130.
Old 03-06-2011, 10:28 PM
C4CRNA
C4CRNA's Avatar
The "autozone guys" are posting it on their resume".
Ya! We work on Porsches>
Old 03-06-2011, 11:04 PM
Sneaky Pete
I ordered online for a 'at store' pick up. Living South of Indianapolis there are not many Pcars in my immediate area. When I went to the store and said I was picking up the battery for my Porsche one guy says 'You got one of them Boxes?'. When he saw the car he said this was the first time he saw a Carrera GT in person...he usually saw it on his Xbox.
Can't make that up.
Old 03-07-2011, 09:51 AM
ivangene
Parts Specialist
ivangene's Avatar
hahaha
thats funny Pete
Old 06-04-2011, 04:16 PM
PasPar2
PasPar2's Avatar
is the gt3 battey different then the 996c2 battery? I need to pick one up and autozone is telling me I need the H6-DLG not the 48-DL
Old 06-04-2011, 04:56 PM
C4CRNA
C4CRNA's Avatar
The group 48 is a perfect fit
Old 06-05-2011, 01:38 AM
fpb111
fpb111's Avatar
The H6-DLG is a little longer. You will have to use the next threaded hole in the pan. 4th pic in post #1 shows it.
Old 06-05-2011, 02:11 AM
SSST
SSST's Avatar
Only on Rennlist would weighing your battery not be considered weird. Lol
Old 06-05-2011, 09:31 AM
PasPar2
PasPar2's Avatar
got the 48-dl and put it in this am. It uses a different hold down hole than my OEM Moll but fits well and very secure. Autozone counter guy "guaranteed" its the wrong battery BTW and wanted me to get the $190 one (Porsche tax?). I did compared the 48 and the one their computer shows and they are identical in size...
Price is up to $130 (with NY tax) these days.
Thanks everyone for posting this valuable info.
Quick Reply: NEW BATTERY INSTALL - Duralast 48-DL [autozone] March 2011
