Oil Leak - Driver's Side (not RMS)?
I have a small oil leak, on the driver's side (U.S., left hand side). It seems to come from the front of the engine, but not where the transmission meets the engine. Instead, it seems to come from NEXT to the transmission somewhere, but I can't tell where. It runs down the engine, and collects as shown in the picture. I get maybe a few drips per day on the garage floor.
It is not coming from spark plug tubes; I just did those. It's a '99 C2. with 53k miles.
Thanks for the help.
AOS most likely. Could also be cam advance solenoid leaking at the seal. Least likely would be the scavenger pump, looks like there is oil higher than the scavenger pump though.
Oil Leak - Cause found and repaired
It turns out my oil leak was the Air Oil Separator (AOS), as predicted by the gurus here. Had it replaced when my clutch was done.
