996 Forum 1999-2005
The IMS discussion thread (Read this first!)
Old 07-03-2014, 11:27 AM
  #31
5CHN3LL
5CHN3LL's Avatar
<Opinion>
Since that precedent of excluding cars that had been in service for more than 10 years was set in the existing settlement, I think it's unlikely to see any additional suit addressing the older cars (primarily because the attorneys will figure that the money has been made off of this topic and will move on to greener pastures).
</Opinion>
Originally Posted by 487
does anyone know of a class action suit covering earlier 996s regarding IMS, I have a 99 with as yet no problems
Old 07-05-2014, 06:02 PM
  #32
pantdino
pantdino's Avatar
What percent of 2000 MY cars had the double row IMS bearing?
I understand no one knows exactly, but is there a general feeling that half or 2/3 or whatever of the 2000 cars still had the double row?
Old 09-05-2014, 10:29 AM
  #33
D6lc
D6lc's Avatar
So this winter I am going to drop my tranny and check/replace my clutch. It pisses me off to say this but whilst doing it I will do the IMS, I don’t for one second think it needs it, but when I come to sell the car anyone with an ounce of intelligence will do an internet search and read the hype.
So I don’t want to pay LN for all their marketing hype and fork out $600 for the kit, I like the look of the Pelican kit, but wondered if anyone has purchased their own ceramic bearing to put in the pelican kit?
Old 09-05-2014, 10:35 AM
  #34
D6lc
D6lc's Avatar
scrap my question, I just watched Pedro's youtube showing a brand new ceramic vs a ceramic with 45k on, no way I am fitting one of those to my engine. I'll go with the full Pelican kit
Old 10-09-2014, 09:48 PM
  #35
DTMiller
DTMiller's Avatar
I just want to post in the four year old thread which no one reads even though the title says to read it first.
pcraddock (02-28-2024)
Old 10-24-2014, 11:48 PM
  #36
santana86
santana86's Avatar
I just had my IMSB replaced with a LN engineering bearing. I had it done along with the clutch, flywheel, aos, water pump, thermostat, fluids, etc...
Eurotech Motorsports in Natick, Ma did the work, great experience, no issues at all. I've been taking my cars to Farley (head mechanic and owner) for years now, great guy, very honest and reasonable. I recommend Eurotech to anyone who needs any work done on their Porsche (Farley is a former 996 owner).
15A Cochituate
Natick, Massachusetts 01760
Phone (508) 647-3799
Email eurotechnatick@yahoo.com
Old 11-02-2014, 09:11 AM
  #37
tlisotta
tlisotta's Avatar
15A Cochituate
What did that run cost wise? I am in the market for a 996 and want to budget for this when looking
Old 11-02-2014, 09:15 PM
  #38
santana86
santana86's Avatar
The total in parts was about 3000, and the labor was less then 2000; I did do more than what was required, but I had built in 5k into my budget when I was looking for my car, so I maxed that..., but I am now very confident when I drive my car that I will not have any major issues in the near future.
Good luck with your search.
Old 11-03-2014, 07:55 AM
  #39
tlisotta
tlisotta's Avatar
Thank you!
Old 11-08-2014, 03:58 AM
  #40
vargas
vargas's Avatar
Hello everyone,
first post here...
I've always been an air cooled 911 owner but have now recently purchased an '02 C4S that was once a CPO. This 996 has 38k miles and in the service history, it shows a RMS replacement back at about 11k miles done by Porsche. I called the dealer to inquire if they serviced the IMS but they could not verify. How can I look further into this? I have called Porsche and they are unable to help. I've driven this 996 @ relatively high RPM's prior to inspection and after. Runs solid...should I be concerned?
Thank you in advances to all responses!
Old 11-12-2014, 04:36 PM
  #41
Hardback
Hardback's Avatar
Originally Posted by vargas
Hello everyone,
first post here...
I would just drive the car and enjoy it for now. You can install a magnetic drain plug to catch any metals floating in oil, cheap mod. A lot of members will tell you that if IMS bearing is concerning you then replace at time of new clutch for peace of mind. Good luck with your new 4S! And thanks for using this thread to post your question.
Old 11-17-2014, 06:14 PM
  #42
aggravation
aggravation's Avatar
Is there a range of model years that the service of, or similar to, the IMSB is easier to do?
I think I read some mention of a range of years where the engine had to be opened up to retrofit or replace the IMSB. Other threads seem to imply you just drop the transmission.
Am I confusing some other component with the IMSB? Maybe it was early 997's?
And I put this question here primarily because I don't want to **** people off who are sick of the IMSB topics but the real crux of my curiosity is to identify which engines are more or less friendly to important service...be it IMSB or other components that require service.
Thanks!
Old 11-17-2014, 07:50 PM
  #43
Ahsai
Ahsai's Avatar
Thanks for using this thread for IMSB. Only 997s need engine opened up to address the IMSB (except some earlier 997.1). All 996 IMSB can be addressed with just the transmission drop and not opening up the engine.
Old 11-18-2014, 07:00 PM
  #44
JMLavoie
JMLavoie's Avatar
I have a '00 C2 as well.
Mine is an early build: Last 4 numbers of VIN are ...0220 and it was assembled in Aug 99. So I should be 99% sure I have a dual row.
My take on this is if your car was assembled closer to May 01, there is a slight chance it could feature a single row bearing but again much more likely it will have a dual-row.
Porsche's configuration control appears to be in the realm of a crapshoot when it comes to IMS bearings in 99Sixes.
My 2 CDN cents!
Old 11-20-2014, 10:51 PM
  #45
JD ARTHUR
JD ARTHUR's Avatar
Mine ends in 3075. How do you know when it was built? Mine had the double row bearing.
Quick Reply: The IMS discussion thread (Read this first!)
