The IMS discussion thread (Read this first!)
#211
Can't believe that there are no certified installers in the NY, NJ or Ct. area with all the Porsches around here.
#212
Former Vendor
They failed to exercise the proper judgment on one occasion, and retrofitted an engine that had a failing original bearing. The same day that LN received their bearing registration, with the failing bearing included, I pulled their Certification status. Pure stupidity was executed on that one.
There's no margin of error for these installers. One goof, and they are done. Its tough to attain the Certification, and even tougher to retain it. These shops can't just Retrofit every car that comes in their doors, like other shops continue to do.
The right installer hasn't come our way yet from that region.
#213
We had one Certified Installer in NJ.
Curious...What was done for the customer after this was discovered?
#214
Former Vendor
Any issue would ha e been between the shop and the owner, and no warranty claims were ever made, so it must have worked out ok. That was over 3 years ago.
#215
I believe the shop got the car back at their location and carried out some oil flushes. Other than that, I have no idea.
#216
Hartech IMS thread
I read this
http://www.911uk.com/viewtopic.php?t=108257
pretty interesting, has anyone done this with any level of success in the US ?
I read this
#219
Hartech IMS thread
I read this
I read this
#220
Former Vendor
Hartech IMS thread
I read this
I read this
In the old days, before I developed the IMS Retrofit procedure the factory and everyone else said the IMS Bearing was non- removable. It was said to be impossible.
One of the very early things we started doing to extend the lives of original bearings during this initial period was to remove the seal, as mentioned in the thread you referenced. It's all we could do with the engine assembled, at the time. It's also the reason why the LN Engineering Retrofit bearings have no seal, and never have.
Now, this does help; but, the major issue with doing only this today is all the years of wear that the Bearing has seen before pulling the seal.
Also, since the major issue effecting these bearings is load. Increasing lubrication may help keep the bearing cooler, but load isn't addressed.
The reason why M97 bearings have proven not to fail is because they are 26% larger in diameter and can carry more load.
Please don't confuse The IMS Solution with a "DOF" system. Look up US Patent 9,416,697 and see who holds the Patent to remote oil delivery (by any means) to the IMS region. FYI
#221
I had the CSR installed just over 2 years ago, and it is an open seal design, my OEM sits (like others)
as a paperweight, completely void of grease
Spin on oil filter adapter and the recommended NAPA filter
I changed the oil 1,700 miles after the retrofit ( done@ 27,000) and that filter was perfectly clean (still stored)
and changed the filter again at 31,600 when I installed the filter adapter, again perfectly clean
and the UOA with oil change was excellent
#223
what is the difference in load between the early Classic Single Row and OEM ?
The Single Row Pro, by adding a second row of *****, doubles the load capacity. Until Jake figured out a method to retain and tool to install a dual row bearing into a single row shaft, a classic single row IMS Retrofit OR IMS Solution were the only options available.
The reason why the factory dual row bearing has such a lower reported rate of failure is because it has double the load capacity of the later single row bearing used.
By using an open bearing, the IMS bearing is exposed to an oil bath. Remember, the M96/M97 engine is wet sump, not dry sump!
Using a quality oil, having a low temperature thermostat, and adding extra cooling via larger radiators or external oil cooler to the engine, or adding extra oil capacity are all things that can directly affect bearing and engine life.
#224
Thanks Charles, Jake
just curious if there were any long term results from M96's with the just the seal pulled
They have quite a different attitude across the pond
I'm quite happy with the CSR and spin on adaptor
#225
As someone about to take delivery of an '02 C4S, I want to thank you all for taking the time to provide the content in this thread.
I don't want to spend 50%+ of the car I'm buying on rebuilding a motor, so it appears I'll be having the IMS Solution installed.
Jake, you seem to have one installer in/around Toronto - Liam Kelly & Keltech Performance. I've never heard of his shop. He's definitely not one of the 3-5 go-to shops in the Canadian section of this forum. Have you sold him many of these kits?
