ZR rated tire with patch in sidewall.
Ok I found online a 275 35 18 with 90% tread remaining for a pretty good deal it seems, but there's a catch... it has a small hole in the sidewall that has been patched. I have a matching tire at home is the only reason I would even consider this. Am I correct in believing that patching a zr rated tire is a big no no due to it's performance? I'd hate for this thing to blow up while going over 100. Any input from you guys would be appreciated. Thanks, Tim
In all cases though hole has to be small (1/4" is largest diameter I can recall being allowed), located _inside_ the tread area. Any holes, punctures, cuts outside of the tread area -- and of course this includes the sidewall areas -- are not fixable.
You should give online patched tire a miss. The tire is not safe.
Sincerely,
Macster.
But this is about as far as I'd go and I may have erred in not replacing both tires though car acted ok with the different tires and nothing came from doing this. Other sources tell me generally 15% is the cut off point. If tires worn just 15% under new both tires should be replaced if one damaged and unrepairable.
Sincerely,
Macster.
I'd run it, but I'd also keep the speeds down to the legal limit. and wouldn't drive super aggressively, keep your inflation pressures up. Heat is the enemy. If you have a problem, it would most likely start loosing air slowly and this would be noticed if you are in tune to your car and driving. These very low profile tires have extremely stiff sidewalls and even if you loose air rather suddenly, control is usually easy to maintain, especially compared to the old 100% aspect high sidewall tires. Dont try this but I have ridden a GSXR with a 100% flat front tire at up to 100mph, felt pretty good over 50-60mph and up. below 35mph it got really heavy and ill handleing. If you drive fast and somewhat aggressively, replace it.
Very cool video....wow!! As for sidewall patch...big NO NO.
