Burning smell?
Burning smell?
I have been driving my 996-4 for about 3000 miles and am constantly getting this burning smell from the back of the car like burnt rubber (don't laugh, I know!) after driving it for more than 15 minutes or so. I just changed the oil and filter on it on Friday evening and did not see anything that could be causing the smell. The car appears to be bone dry and the serpentine belt seems fine. Do these cars have problems with the parking brake shoes? It seems to be located under the hood but I can't pinpoint it... Any ideas?
Newbies Hospitality Director
That odor is probably the cosmoline that Porsche uses on the bottom of the engine to protect the engine from the elements. When the cosmoline gets warm it gives off a particular odor.
It is rubber. It's the rear tires. Touch them after they've warmed up. Probably because they have 60% weight on them, spirited driving and a very slight 'toe-in' setting.
You'll find the rear tires wear out 2x as fast as the fronts.
Same thing with my C4S. I was told it was probably the rear brakes. But the cosmoline and tire rubber make sense. It smells, but there is no smoke anywhere. I was worried that is was oil burning, but smoke would result from the oil burning plus the odor is quite distinctively not oil. It seems to be a common occurance and it goes away in about 5 minutes.
Parts Specialist
run it by your indy or dealr just to make sure it's the "normal smell"
if it is, smile.....
if they think it is not normal - set an apointment to have them look at it and ask if they think it can be driven....
nost likely its normal, namy of us had the same "what's that smell" moment, but its not a bad idea to have a second opinion since we cant actually smell it over the interwebs
Poseur
Another thing to check is your serpentine belt. For old-school 911 guys the smell of burning rubber is pretty much the norm, to a point. I complained about it a few times to my dealership and they blew me off--until the serpentine belt failed prematurely. Check to see if the come-along pulleys are smooth along the belt-ridding surface, or if you have grooves along the sides of the pulley surfaces. Sometimes the belts are just too tight--and that is not adjustable of these engines. Odd!
You can look for oil leakage around the valve covers or other places that sit above the headers. In the picture you'll see an arrow pointing at oil on the header tube and some seapage on the engine. Oil can smell like burning rubber. It's all hydro carbons.
Very normal. Mine smells 25% of the time. Sometimes after a spirited drive, sometimes not. I don't think it's cosmoline though....I have a reman engine in mine and they (famously) are not coated with the yellow goop.
I chalk it up to hot tires...it's definitely a rubber smell and not a clutch, brakes or oil smell. Soft tires, lot's of toe, lot's of weight...makes sense to me although it still catches me off gaurd sometimes and make me wonder.
Oh yeah - my first 996 smelled the same.
They all do it.
They all do it.
Run your finger along the rear bumper near the rear tires after a 100 mile drive on the highway.
Your finger will have black tire residue on it.
The tires wear very quickly.
The smell is part cosmoline and part tire rubber.
Rocky Mountain High
Mine does it too. Definitely smells like burning rubber. I always assumed it was the tires, and I seem to notice it more after a spirited drive. I didn't know about the cosmoline until this thread.
