996 Forum 1999-2005
The New Official "Things you didnt know about your 996" thread
Old 12-19-2009, 04:07 AM
  #106
Psycho Sid
Psycho Sid's Avatar
Originally Posted by rrspikemarty
2003 C4S gas tank design is such that if the gas in the tank falls and remains below a certain level, the gas gauge does not register gas added to tank. I have not figured exactly where that point is, but in my C4S, if my gas has fallen below that magic level, i have to add approximately 1/2 tank of gas for the gauge to begin registering correct levels again.
This is an atrocious design flaw, and doesn't indicate a gas gauge fault.
Hey rrspikemarty,
I actually recently found out that this is because the gas tank in the 996 C4S is made out of 2 separate tanks connected by an "overflow" (much like in a plane), this was done for space and weight distribution reasons.
If your car is half full when you start your drive it will give an accurate reading even if it drops below the "overflow" connector ( by computing based on the data from one fuel tank) , however if you then park your car with lower fuel levels (and you start it up again) it only reads the fuel in 1 of the 2 tanks.
Thats why it's good idea never to let your fuel levels drop below 1/3
Hey I contributed something
Cheers,
Sid
Old 12-19-2009, 09:48 PM
  #107
rrspikemarty
6th Gear
rrspikemarty's Avatar
yeah, that's what i'd heard. You'd think a car that has cup holders, would have a better gas gauge ;-)
rrspikemarty out
Old 12-20-2009, 05:44 AM
  #108
Pac996
Pac996's Avatar
About 2 weeks ago I bought the car and just yesterday I was reading the manual and found out sure enough if I hold the key in the door to unlock or lock the windows operate down or up. Never knew that one. Great trick for here in Hawaii with the heat the sun makes in the car.
Old 12-20-2009, 10:26 AM
  #109
Ahmet
Ahmet's Avatar
Originally Posted by gota911
Another thing.... The driver's side rear fog light is operable but the passenger side rear fog light does not illuminate. It comes that way from the factory.
From my experience this is not unique to the 996 or Porsche. I believe they do this to make the foglight more noticeable.
Old 01-13-2010, 01:24 PM
  #110
Steve-o
Steve-o's Avatar
Default Is it true
(as I've been told) tiptronics have 2 gears in reverse?
Old 01-30-2010, 12:37 AM
  #111
4Scargo
4Scargo's Avatar
Okay, I have been throwing a CEL light ever since I got my car. I bought a Code Reader (Harbor Frieght $56) and it pulled up Code 1126 & 1137 (I think) for bad pre cat O2 sensors. I removed them and cleaned them, no luck, replaced the left one with a used one......no luck. The CEL would come on just as the car would come up to temperature on the water temp.....60% of the time. Installed a new MAF
BINGO - JACK'S A DONUT - THAT FIXED IT!!!
Old 02-05-2010, 09:41 PM
  #112
tntempest
tntempest's Avatar
Three things that make me cringe I learned from my 1999 Dealer brochure that just came in. And I quote from page 15
"Each engine is tested rigorously---on the bench for up to half an hour, with a full minute nonstop at redline!!!!!!!!!
Then a rolling road test. And ultimately , the final exam: 90 minutes on the Autobahn, where every 911 off the assembly line must satisfy perhaps the worlds most demanding , and some say most fortunate, driver- a Porsche test driver."
"Each new 911 must slow from 90% of its top speed to 62mph 25 times. Consecutively. Without suffering significant brake fade."
1. So there are two schools of thought on breaking in a motor, apparently Porsche takes the rough road.
2. Some yahoo was given the keys to my car for 90 minutes at unlimited speeds when it had no miles and the crap was beaten out of it and the factory sanctions it.
3. Our cars are place under load to 156.6mph 25 times in a row when they are brand new and the brake pads are not broken in any way I have ever read about. There would be no reason to try and break in your new Porsche when you received, because the darn thing is beat all to heck anyway.
This could explain a lot with these engines, would be a neat graph to see trans bearings and IMS failures vs test drivers name.
Old 02-09-2010, 04:14 PM
  #113
150shot
150shot's Avatar
I guess this can go here..but do aftermarket wheels for a 996 WB also fit to a 997 WB?
Old 02-09-2010, 04:24 PM
  #114
ivangene
Parts Specialist
ivangene's Avatar
In general this question would be better off on its own thread, this my not get much attention on this one....
I think the answer in the vauge sense is YES, but 997's also come with 19" wheels and for those I dont know the fitment. (you said aftermarket) The best thing to do is to post what the potential wheels you are looking to fit onto the 996 WB including width and offsets for front and rear - then you get get a specific answer. I am almost 100% certain the 996 WB will fit the 997 though maybe not the other way around in ALL cases
Old 02-11-2010, 01:35 AM
  #115
Airrik
Airrik's Avatar
Really I didn't know that 9 lives.. which buttons do I push on the climate control?? I have an 2001 996 Emerald Green Mica.
Old 02-16-2010, 07:37 PM
  #116
Shark Attack
Shark Attack's Avatar
I duel row IMS bearing with the internal clip CAN be removed while the engine is in the car.
Old 02-16-2010, 08:08 PM
  #117
gota911
Newbies Hospitality Director
gota911's Avatar
.... and all you need is an old tree stump to prop it up!
Old 02-16-2010, 08:53 PM
  #118
ivangene
Parts Specialist
ivangene's Avatar
You will miss your car when it's gone..... and even if you replace it, there will never be one just like it. Live in the moment and be thankful for today
The following 4 users liked this post by ivangene:
9SIX4-C4 (08-15-2019), Amanda Miller (11-16-2020), bms0918 (10-08-2020), SARNODUDE (08-08-2023)
Old 02-16-2010, 09:26 PM
  #119
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
Received 1,234 Likes on 754 Posts
Your rear tires will last a LOT longer if you set the camber to neutral, which is the least they can be set at.
"stabbing" the throttle on a tip will immediately shift the transmission to the lowest gear possible for the speed you are traveling. It will hold it there for approx 8 seconds unless other throttle input is applied.
The PSM computer does some interesting things on its own volition. I have to refresh my memory on that though.
Old 02-16-2010, 10:41 PM
  #120
ivangene
Parts Specialist
ivangene's Avatar
BORING
Quick Reply: The New Official "Things you didnt know about your 996" thread
