The New Official "Things you didnt know about your 996" thread
#61
Here's one that hasn't come up yet.
The oil filler pipe can be unclipped from the airbox. There's a bellows section in the pipe which then let's you tilt the pipe up a good 6 inches to make adding oil a no-mess breeze.
Used this today when I did my oil change.
The following 2 users liked this post by jasper:
9!!_VA (06-13-2021),
janikphoto (04-04-2020)
#62
The little led that is in the middle of the dash right under the windshield lights up red in conjuction with the led on the key remote to let you know it is working.
PCM 2 has a lot of out-there features such as a setting for calibrating the trip computer for each time you get new tires.
It also can detect CD names / track names for most CDs, even if they are a mix cd made by the user. For CDs that don't have readable track data, you can enter the name of the cd in PCM 2 so that it will show up in the CD list for the CD changer.
#64
Lol.
The following 3 users liked this post by 911_993_997:
#67
what I learned looking for tranny oil for my 2002 996 tip:
The tip-S is is made by Mercedes Benz and is also used in many MB cars, as well as some Dodges and Chryslers. The transmission is called "722.6". It is considered "bullet proof" mechanically and mostly suffers from electronic issues rather then mechanical. Some 722.6's have a bolt on the torque converter to allow draining the oil - the 996 version doesnt not. This tranny installed in most MB models has a filler tube in the engine compartment but the dip stick needs to be purchased separately. The 996 version doesnt have a filler tube and gets filled via a fill bolt on the transmission.
the correct fluid for this tranny is the fuchs 3353 labels "Titan" available from Pelican parts. The gasket and filter look identical to the MB spec ones but cost 3x and 7x more respectively for the Porsche.
#69
Although not confirmed myself, I have read that the Tip cars have a direct pulley on the alternator while the manuals have a sprag type pulley.
I remember my Tip alt pulley was solid.
Can anyone confirm this?
#70
#71
And here I thought Porsche owners were too bright to believe that CRAP..!!
Maybe in the general case.
Even if the ECU does "learn", adapt, to some aspects of your driving habits those will be, MUST, be erased upon each engine stop/start cycle.
#72
Yes the 996 Tiptronic S transmission is a MBZ tranny. As for the AWD cars, C4, C4S, Turbo, only the 996 Turbo Tiptronic uses another MBZ tranny (F-1) with different OEM part number and they are not interchangeable due to bolt pattern. If you build an aspirated 996 with more horsepower (ie supercharger) you may risk damage to the Tiptronic Transmission, if you were thinking "the Tiptronic, if it can withstand the bHP from a turbo, then it is okay for a supercharger" idea. Not.
#73
"..The ecu will adapt to your driving habits.."
#74
I'm guessing this is this to decrease drag on the motor, and help keep revs up when shifting???
#75
huh? So, when you put an exhaust or a cai... the ecu wont know the diff between aftermarket or stock?
Not immediately, not unless you "tell" it.
The engine management on these cars are adaptive... just about any modern sports cars have this feature. When you unplug the battery, ("telling" it") the mapping goes to default... as you drive... the car learns your driving habits.
No, it learns new engine/sensor/control mapping parameters while you drive, based on how you drive, NOT YOUR driving habits.
In other words... it re-maps itself based on trending patterns of the way you drive.
Once a parameter is "mapped" it will not be re-learned in accordance with ANYONE's driving habits. Excluding driver unique parameters that are ERASED upon each stop/start cycle, MUST be erased.
Modify the engine in some manner and the ECU will eventually learn new parameters if/as needed. Or you can disconnect the battery for a period and the ECU will adapt to the "new" parameters more quickly.
