996 Forum 1999-2005
The New Official "Things you didnt know about your 996" thread
Old 05-10-2016, 08:45 PM
  #466
Woodman71
Woodman71's Avatar
Originally Posted by krazyk86cu
This may be common sense to some, but I literally just figured out that you are supposed to place the windscreen on top of this little ****. Makes the windscreen much more rigid.
Wait, the little **** gets more rigid in the wind?
Old 05-23-2016, 02:27 PM
  #467
Woodman71
Woodman71's Avatar
Well, I noticed this little guy inside my engine lid yesterday.
I didn't know they put that on their after doing the retrofit.
Old 05-23-2016, 03:27 PM
  #468
lomax
lomax's Avatar
Thanks for posting that. I got the sticker by never knew where I was supposed to stick it.
Marc
Old 05-23-2016, 03:38 PM
  #469
Woodman71
Woodman71's Avatar
Marc
I saw it and thought, "Damn, I hope that wasn't on there before I paid the shop to 'replace' the old one..."
Old 06-01-2016, 02:23 PM
  #470
Woodman71
Woodman71's Avatar
OFf
Old 06-01-2016, 02:32 PM
  #471
Arch1t3ct
Arch1t3ct's Avatar
Originally Posted by Woodman71
OFf
This may have just ruined the 996 for me. Cannot un-see.
Old 06-05-2016, 03:29 PM
  #472
Woodman71
Woodman71's Avatar
I think I discovered what the back seats were designed for.
Old 06-24-2016, 12:34 AM
  #473
2004-911 carrera
2004-911 carrera's Avatar
dumb, but that 6th gear wasn't reverse-after taking a closer look at my ***-getting lots better MPG on the Highway now 25mpg 1st 6 speed I've ever driven
Old 06-24-2016, 08:57 PM
  #474
Woodman71
Woodman71's Avatar
This boggles my mind a bit. Had you never used reverse before, or were you putting it in 6th trying to reverse, and wondering why it always stalled?
Or you thought there were two reverse gears?
Old 06-25-2016, 10:36 AM
  #475
2004-911 carrera
justhad never driven a 6 speed before anad hadn't had much freeway time--5th took me more then fast enough to get a ticket--I've had to glance at the online manual for lots of things--sure is nice tacking low now with the cruise control on to keep me away from Tickets--have been pulled over twice sine I bought the car--when they couldn't read my temp registration in the back window--rhe dealer took a month to send the title to my bank and I'm still not in the system when I get pulled over
Old 06-27-2016, 01:28 PM
  #476
Woodman71
Woodman71's Avatar
So, yesterday I learned if your sun shade slips while the car is locked, it can (and did) set off the alarm. Luckily I was at home and it wasn't 2 in the morning.
Old 06-28-2016, 08:35 PM
  #477
TheKane
TheKane's Avatar
On both my cars, when filling up gas at California pumps, it clicks off due to back pressure before completely full. I had to hold the rubber neck back from the opening to let air escape between it and the filler neck. My vents have been cleaned and are unblocked. Everyone I know has this issue (996TT's, 997 GT3's, Boxster Spyders, etc.).
If you insert the nozzle then rotate it 90 degrees so it's upside down, there will be a little gap at the top of the filler neck, and you can fill all the way up without it clicking off prematurely. You will have to stand there and make sure the nozzle doesn't fall over and out, but it won't click off and you won't get gas fumes on your hands.
Old 06-29-2016, 07:22 PM
  #478
jhbrennan
jhbrennan's Avatar
You need this:
http://www.suncoastparts.com/product/PK9X7NOZZLE.html
Old 06-29-2016, 07:30 PM
  #479
Woodman71
Woodman71's Avatar
Originally Posted by jhbrennan
Well, dang. This might explain my 13 mpg calculation...
EDIT: Nope, nevermind, doesn't apply to '99. Must be my heavy foot.
Old 07-07-2016, 06:17 PM
  #480
saline
saline's Avatar
Default 2004 and newer speedos are different from earlier ones
2004 was the only year that had one touch operation and would operate at speed. If you swap an older speedo with your 2004 996, the top only works when driving, not while stopped. The reason is that the newer speedos send a 0.5 MPH signal to the newer controllers. Without a motion signal to the new controller, the top will not operate. You can get a older top controller, or go to Mods4Cars for a solution. After a year on every Porsche forum I could think of, Mods4Cars told me what the problem was immediately and had a solution.
Quick Reply: The New Official "Things you didnt know about your 996" thread
