The New Official "Things you didnt know about your 996" thread
#151
Drivers used to have to run to their cars at the start of the 24hr. Le Mans race. This starting method inspired Porsche to locate the ignition key switch to the left of the steering wheel. In a left-hand drive car, this allowed the driver to use his left hand to start the engine, and his right hand to put the transmission into gear, which in turn shaves off a few tenths of a second.
How bout that
How bout that
#152
Is that true? This is exactly happenned to my 2000 C2 Cab. My friend told me that the passenger side fog light is off, I then checked it and found no bulb in the socket. Installed the bulb but it did not lightup, checked the voltage and zero volt. Swapped the whole lamp module from left to right and right to left; the passenger side fog light still off.
I thought the electrical wire is broken somewhere and plan to add jumper wire from the driver side light to the passenger side.
Should I do this and do you know why it came from the factory like this?
Thanks.
Nghia Ho
Thanks.
Nghia Ho
Thus, the logic there is the marker on the left side helps to indicate where/how to pass.
(Of course, passing on the right on the Autobahn or highways is not allowed.)
#153
1 Post
Since I was born and raised in Europe (Holland) I know a bit about this topic, originally the fog light was a separate unit mounted below the rear bumper on drivers side, later it was incorporated into the actual taillight housing.
The reason for having only one is to distinguish the difference between a brake light and a fog light (European cars did not have 3rd brake lights).
The reason it's on the drivers side is because this is the most visible locating, in England the fog light is on the right.
Manufactures found it was more cost efficient to put the same amount of sockets in both taillight while using the same wiring harness this way they simply installed a dummy bulb on whichever side they do not want active..
On my P. I have blacked-out taillights, in order to compensate for the loss off brightness I replaced the dummy bulb with a real one and wired both fog lights in with the normal nighttime light-sockets, thereby doubling the light output (standard taillight is 2x 5W. the fog light is 21 W.).
If your interested to see more on this check out https://rennlist.com/forums/996-foru...r-stuff-2.html
Cheers,
Sid.
Cheers,
Sid.
#156
The dealer can correct this. This was a hot topic on P related forums 7-8 years ago. Dealer corrected speedo on wife's Boxster in '03 and as I recall it was near dead on at freeway speeds compared to GPS.
#157
Interesting, Nick. What are the chances I can get my dealer to correct the speedo error on my 2001 986 S? Do you remember if they charged you? Mine seems to be off about 8%, regardless of speed.
#158
1 Post
If you've got either one of those different than stock it will change your speedo read out.
Larger= lower reading
smaller= higher reading
OK, near dead is definitely not the wheel set up...
Cheers,
Sid.
#159
Well, I called my dealer and they said there's nothing they can do. My wheel and tires are OEM 18s. I've had plenty of bad experiences at this dealer and wouldn't be surprised if I got bad info. Can others on here verify they had a dealer adjust their speedo readout?
#160
now you tell me
thx cargo, mine is doin that, & i can't remember which one i put it in though: how do i find out which one it is? & will they just go off after i put the correct one in, or do i have to re-set something.
#162
Without having the key in the ignition, the stock CD-220 or CDR-220 radio will turn on if you press the "on" button on the radio face. It will stay on for 1 hour, then shut off automatically.
Also, after removing the key, if you press the radio "on" button within 2 seconds, it will stay on.
SF Neunelfer (09-22-2019)
#163
I asked my dealer about the spedo when I was in for an alignment and was told that the spedo reads high by design and cannot be adjusted. I was mostly concerned b/c it seemed my odometer was reading slightly higher than the GPS as well, and while it does, it is only fractional (<1% different from GPS).
From reading other forums it appears the laws in Germany mandate that a manufacturer must produce a speedometer that reads within 10% (I believe) of actual speed, but that it cannot under any circumstances record speed lower than actual. Porsche decided to err on the side of caution as tire wear etc., will change the speedometer reading fractionally.
#164
Parking in Shopping centers
It is unbelievable but true. I park in the middle of freaking nowhere and when I return... cars on both sides... and not nice ones either. Any speculation regarding the reason for this?
#165
Range Master
Pepsie Lite
Pepsie Lite
the cars come with the "a-hole magnet" option turned on, and you hafta have the dealer turn it off????????????????????
