Power Locks, Rear Defroster, and interior lights stopped working?
I have a 99 C2 Manual. Last week, I noticed the interior lights stopped working. When the door opens or when I try to switch the lights on, it will not turn on (all 3 of them).
Then, I noticed that the power locks do not work. If i turn the key to lock the driver side door, only that door will lock. The passenger side door remains unlocked. I also cannot open the hood (the latch will not press down - as it does when the doors are locked). The defroter switch and the door lock switch do not work at all.
Does anyone have any idea what this could be? The first thing I did was check the fuse box by the drivers side seat. All of the fuses seem fine.
Has anyone experienced somehting like this?
I dont know if this is related at all, but my alarm system hasn't been working for about a year. The button on the keys does not activate/deactivate it. I usually turn the keys twice to activate the alarm. Not sure if this is related at all, since it has always been this way.
I would first check the relays for the interior accessories that are not working.
If not done already, try replacing the battery in the remote.
Radio and A/C works fine. Although the radio does get glitchy sometimes (but never stops working)
How can I check the ignition switch?
If that is the problem, you can get a replacement switch for $20-$30 and DIY. Or, you could replace the whole ignition switch/lock part for over $100. It's an easy and quick DIY, but needs some contortionist skills!
Fuses are th first thing I checked. No work has been done on the car recently. Clutch/flywheel/RMS was changed 3 months ago.
Does anyone know where I can find the relay switches?
auto-xr should be a good help with looking at the C3 fuse. Figuring out the right fuse is a problem. Trouble shooting is often the main problem. There is also a chance those devises uses a common ground and the ground wire disconnected which would mimic the same as a fuse problem. No ground-no power flow just like no fuse.
