996 Forum 1999-2005
CEL issues
Old 11-19-2007, 12:43 AM
wwboater
wwboater's Avatar
Default CEL issues
Could a hole in the oil separator breather hose cause fault codes p1124 and p1126? I have cleaned the Maf and still get the codes and rough idle. I noticed that I have a hole in this line because it has been rubbing on the intake system.
Old 11-19-2007, 10:15 AM
Seeeu911
Seeeu911's Avatar
I have those same 2 codes and a leak in the AOS bellows.....plus a oil leak.
Old 11-19-2007, 11:19 AM
Tippy
Tippy's Avatar
To tell if you have a hole in the oil separator, remove the oil cap and see if the engine runs rough or dies. Also, place your hand over the filler tube opening and see if there is a strong vacuum pull. If you have the symptoms, the diaphram has cracked or ruptured.
Old 11-19-2007, 11:38 AM
wross996tt
wross996tt's Avatar
P1124 167 Fuel pump relay output stage - below limit
Possible fault cause:
♦ Fuel pump relay
♦ Short circuit to ground
♦ DME control module
P1126 356 Oxygen Sensing Adaptation, Lower Load Range,
Bank 1 - Below Limit
♦ Incorrect signal from MAF sensor
♦ Fuel pressure too high
♦ Fuel injector leaking
Old 11-19-2007, 11:58 AM
1999Porsche911
1999Porsche911's Avatar
♦ Fuel pump relay
Here are the correct indications:
P1124
Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Rich Threshold
P1126
Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Rich Threshold
You are running lean on both banks which could be caused by intake leak, wrong MAF signal, vacuum leak, bad plugs, low fuel pressure, leak in exhaust system, fouled injectors and other possabilities.
The errors are generated at idle.
Old 11-19-2007, 12:08 PM
wross996tt
wross996tt's Avatar
hmmmm...those codes are right out of the workshop manual? This is DME 7.8.
Also same info as I posted from Renntech RennTech P1124
P1124 167 Fuel pump relay output stage - Below Limit, 167 Fuel pump relay output stage - Above Limit, 167 Fuel pump relay output stage - Open circuit
Old 11-19-2007, 02:14 PM
wwboater
wwboater's Avatar
Well since the car was just purchased the dealer is taking car of this problem. So when I get it back I will let you all know what he did to fix it. Thanks for the advice...
Old 11-19-2007, 02:28 PM
Tippy
Tippy's Avatar
P1124
P1126
With those codes, I bet that the MAF is dead causing a lean condition.
According to 2 mechs and 2 service advisors, anytime they get 02 issues, it is always the MAF that is dead and the OBD II thinks it is the 02 sensors that are the issue since the 02 sensors will below min value. This was the case with my car.
Old 11-19-2007, 02:49 PM
1999Porsche911
The computer DOES NOT think the problem is with the O2 sensors. It is simply reporting that the sensors are working properly and that you have a lean condition in the exhaust of both banks. Cause could be any of a dozen number of things or combination of them. Any problem that allows more air into the engine or to the O2 sensors that is not reported to the computer or any problem that allows for less fuel to be delivered than the engine calls for.
Old 11-19-2007, 03:11 PM
wwboater
wwboater's Avatar
I changed the MAF out with a new one and it did not fix the problem. So now I have a new MAF for sale. Any takers?
Old 11-19-2007, 03:53 PM
Tippy
Tippy's Avatar
How much?
Old 11-19-2007, 03:58 PM
Tippy
Tippy's Avatar
Ok, based on what you said, it is a lean condition. 2 mechs and 2 service advisors told me that the MAF dying would cause codes from the 02 sensors If the 02 sensors are dead or simply out of range. Apparantly, the OPs MAF was not the case. But to others who have these issues, I have been chasing a similar lean condition for a week now and that is the reason I stated the MAF may be a possible cause. I will know tomorrow.
Old 11-19-2007, 05:32 PM
wwboater
wwboater's Avatar
Originally Posted by Tippy
How much?
$250 shipped to your door.
Old 11-19-2007, 05:49 PM
1999Porsche911
For the price you paid for the MAF, you could have purchased a scanner or scanning software for your PC. Why diagnose blind when there are the tools available for you to see?
Old 11-19-2007, 05:56 PM
1999Porsche911
If you have a scanner, take a look at your MAF readings at idle. That will tell you if it is bad or not.
Quick Reply: CEL issues
