PS2 Scans at Farler Performance
Went over to Ken Farlers today to try out his new PS2 unit. Quite impressive. Ken scanned all the DME and other sections and found a few fault codes:
P0300 Misfire
P0306, 3, 5
P0507 Idle Stop
Reset the faults to 0
Car has 783 hrs on the enigine, confirmed milage.
Found a PSM code of 8074?, Noted torque drive set at 19.9%. Seems you can change this if you were so inclined.
Performed the test on the low and high lift on the variocam, passed.
Number of program ops = 2 in the DME section. Noted Porsche.
Checked a bunch of other stuff which I don't recall at the moment.
All in all fun to play with. If you are in the Cincy area and need diagnostics on a 996, 964, 993, GT3 or Turbo Ken can now do the job. 513.932.1535
P0300 Misfire
P0306, 3, 5
P0507 Idle Stop
