litronic projector beam adjustment
Hi, recently replaced my halogens with the litronic xenon factory units, which if bought from the factory, has an adjustment to move the projector beam depending on speed, does any one know how to manually adjust this angle, to set it and forget it, I saw a rotary switch inside the housing with about 8 points and some abbreviations on it, is this the thing, can my ecu drive this or how do i change it manually. thanks for help from anyone that has this swap.....cnm
Thanks, thats what I was thinking, right now they are aimed dead on, i was thinking about aiming them higher for more distance...i.e. i leveled the car and faced my garage door cnm
Originally Posted by programmatore
Their is no automatic leveling with the Litronics Retrofit Kit -- the auto-leveling only comes with the factory installed Litronics. You would have to adjust Litronic the beams the same way you adjust the halogen beams (there are left-right and up-down adjustments). Check your owner's manual for instructions.
The litronic retrofit kit will, if you install the electronic controller and wiring, include the feature of rotating the xenon (low) beam up to add to the halogen high beam when you select hi-beam on your lights. Its a very nice feature, and makes for a much brighter hi-beam picture.
Wait a minute, I HAVE a 2000 with litronics and I don't see a rotating dial to adjust the beam at all. I recall reading in a prior post that adjustable xenons was not an option in the US. Kim, did I somehow misinterpret what you wrote....or, is this adjustability only available on the retrofit kit?
1. To my knowledge, only non-US cars have the manually adjustable headlight beam that is controlled by the rotating ****.
2. The feature to which my post referred is an automatic adjustment in which the low beam zenon lamp rotates its position upward to complement the position of the halogen hi-beam. No action taken by the driver (other than to select hi-beam), and no rotating **** to play with.
It is my understanding that this is the feature gained by installing the electronic controller & wiring that comes with a 98-01 Litronic factory retrofit kit.
Can the adjuster **** be retrofitted into a 99 OEM lightronics equipped C4? Was driving in Europe at christmas in a B class mercedes which had it and it was very nice to have that feature.
Just my impression.
Well this is getting interesting, I didnt know there was so much to these light units, Ive seen this mechanism work on an Mitsubishi evo 8 and it is a nice feature, as for my litronic swap, i never saw a controller or any other stuff for it, though there is a plug installed on the headlamp housing for something.
Mine came with, in addition to the 2 new light units:
000 044 900 38 - Headlight Control Unit with mounting hardware, and
996 612 988 00 - Electrical wiring harness with 2 4-pin plugs
+ assorted hardware & connectors
It is this controller & wiring that rotates the xenon low beam up to join the halogen high beam when hi beam is selected.
