CEL (P1124/P1126) Resolved!
All of you who guessed that there was a hole in the oil separator bellows give yourselves a pat on the back.
Repair cost was $375 at Momentum Porsche in Houston. Parts cost only $30.
I got one right!!!
I found a small slit in my lower accordion type bellows. Did the change myself from under the car. One hell of a job one handed and only managed to get the bottom quick release metal clip in place. I used a small tie wrap/zip tie on the top part. Hopefully that will do the trick. I am awaiting a gas cable before I can try the car out again. Hope the codes are solved.
