996 Forum 1999-2005
996 Battery 999-611-070-20?
Old 03-04-2004, 02:52 AM
H20996
H20996's Avatar
Default 996 Battery 999-611-070-20?
Hello everyone, been awhile on the site and even longer for the baby in the garage. Went to Stevens Creek Porsche for a new Battery. Part #999-611-070-20? When I got home I have a 999-611-080-00! It seems the difference is the 70ah VS, the 80ah. What is that going to affect if anything? Thanks.
Old 03-04-2004, 04:53 AM
Tool Pants
Tool Pants's Avatar
http://www.pca.org/tech/tech_qa_question.asp?id={1680DBFD-1771-48CD-B3B8-723C996052CF}
Old 03-04-2004, 11:08 AM
Loren
Loren's Avatar
Both are approved batteries for the Carrera. A 70 ah battery should be fine in Hollister, CA (about 20 miles South of my house).
Old 03-04-2004, 03:02 PM
chitownbob
chitownbob's Avatar
why spend so much for an OEM porsche battery which drains so quickly and will probably be bad in 2 years. Why not get an optima or something for less?
Bobby
Old 03-04-2004, 03:30 PM
H20996
H20996's Avatar
Loren, thanks for the input. I spoke with Porsche Monterey and they told me the 80ah is used for cars with the Nav-systems. Also, Porsche no longer makes the 80ah, replaced with the 75ah. Furthermore, the .070.20 ships DRY from Porsche and the dealer fills it with ACID! So we're on the road today !!!!
Old 03-04-2004, 09:00 PM
Arthur
Arthur's Avatar
Bobby, I have a 98 build 996. Original battery still under the plastic cover. I am using the trickle charger from Porsche. I cannot believe it myself.
Old 03-04-2004, 09:54 PM
H20996
H20996's Avatar
I too picked up the trickle charger from the dealer, hence adding more to the bottom line price for the battery as chi pointed out. The point from the dealer however was this, not only should you NOT run other batteries due to the fact that they don't fit real well, Monterey pointed out the P-car system needs a more "STABLE" power source and the after markets do ok for cranking amps, put could potentially cause alt problems and induce whine into the vehicle. Just the messanger !
Quick Reply: 996 Battery 999-611-070-20?
