993 Turbo Forum 1995-1998
Rear suspension
Old 02-13-2017, 02:18 PM
MarinS4
MarinS4's Avatar
I just completed similar upgrades. The new RS style bushings tighten up things nicely.
Will you be replacing the sub-frame bushings?
Old 02-17-2017, 05:36 PM
Hasse993
Hasse993's Avatar
Default Sub frame bushings
Maybe that's the next step for me.
Old 05-09-2017, 12:27 PM
DRPM
DRPM's Avatar
Originally Posted by Hasse993
All the arms off the car and a pic of the fork which is my hero.
Hi
Did you change both bushings on the rear wishbones per the pics?
thanks
Derek
Old 05-09-2017, 12:58 PM
MarinS4
MarinS4's Avatar
Very worthwhile project. I just completed the same along with solidside mounts last summer. The rear got noticeably tighter.
Old 05-09-2017, 05:44 PM
DRPM
DRPM's Avatar
did you use Elephant Racing bushings in the rear?
Old 05-09-2017, 08:40 PM
MarinS4
MarinS4's Avatar
Yes...I used the firmer RS bushings in the control arms. I used the rennline solid subframe mounts for the subframe.
Quick Reply: Rear suspension
