Winter Storage - Rennlist Discussion Forums
Winter Storage
Thread Tools Search this Thread
Old 12-20-2016, 01:23 PM   #1
carguy19
User
Default Winter Storage
What does everyone do for their cars when they store them for the winter?
Mine is on a battery tender now in my garage with a cover over it.
Do any of you guys put the car up? Any other tips you care to share.
Thanks to all and Happy holidays.
carguy19 is offline   Reply With Quote
Old 12-20-2016, 02:33 PM   #2
ronnie993tt
ronnie993tt's Avatar
Suggest a search. There are many, many lengthy, detailed threads on this.
ronnie993tt is offline   Reply With Quote
Old 12-20-2016, 04:04 PM   #3
Campy
Campy's Avatar
Quote:
In fact there is one towards the bottom of this first page ů
http://rennlist.com/forums/993-turbo...3-storage.html
Campy is offline   Reply With Quote
Old 12-29-2016, 06:59 PM   #4
ronnie993tt
Hey Campy. This is jealousy rearing it's ugly head...but.....why would a Texan ever need to worry about vehicle hibernation?!
Old 12-29-2016, 07:11 PM   #5
LexVan
LexVan's Avatar
Here are the main things:
All maintenance up to date
Fresh oil
Fuel stabilized (1 ounce per 2.5 gal gas)
Battery maintainer
Tires to 55-58 PSI
Indoor car cover
Suspend car insurance (collision) and save $$
Locked doors
Secure keys
Extra steps to consider:
Desiccant in cabin
Park on thick mill painter's tarp
Do NOT leave suspension unsprung
Don't start the car until Spring. When ready in the spring, pull DME Fuel Relay, crank engine a few seconds, replace relay, fire engine. Road trip. Fresh gas.
LexVan is offline   Reply With Quote
Old 12-29-2016, 07:29 PM   #6
Campy
Campy's Avatar
my specific situation is more about lack of use then hibernation per se Ronnie … variables work out to be kinda the same
Old 12-30-2016, 07:16 PM   #7
ronnie993tt
Fresh oil
Battery maintainer
Tires to 55-58 PSI
Indoor car cover
Locked doors
Secure keys
Desiccant in cabin
..easier to park on foam pads than change tire pressure and don't forget the sunflower seed loaded mouse traps.
Old 01-03-2017, 05:33 PM   #8
Mike J
Mike J's Avatar
.Don't start the car until Spring. When ready in the spring, pull DME Fuel Relay, crank engine a few seconds, replace relay, fire engine. Road trip. Fresh gas.
I would add to turn the engine over with the DME relay pulled every month or so. This circulates the oil, splashes exposed surfaces including the cams, and repositions the pistons (so the rings are at the different stopped position in the barrels) and the cam rockers, so different cams are in the open positions.
There are no factual studies that I have seen that this makes a difference, but it makes sense to me.
Cheers,
Mike
Mike J is offline   Reply With Quote
Old 01-05-2017, 06:30 PM   #9
ronnie993tt
As **** as I am, this just seems a bit over the top to me Mike. Aren't you worried about burning/wearing out your starter motor?
Old 01-05-2017, 07:18 PM   #10
Mike J
Mike J's Avatar
No worries - I think a 10 second crank every month is not going to significantly add wear, and its much cheaper to replace a starter than have a broken ring ...
You can argue that its good for the starter too, to have the solenoid move once in a while rather than freeze up ...
Cheers,
Mike
Old 01-05-2017, 09:57 PM   #11
racer959
racer959's Avatar
I start up my cars every two weeks and let it get up to temperature. Never had a problem in 35 years.
racer959 is offline   Reply With Quote
Old 01-05-2017, 10:23 PM   #12
Mike J
Mike J's Avatar
Quote:
Do you drive them or let them idle to warm up? An air cooled car takes quite a while to really get up to temperate if idling, and one can argue it never will on a cold day since the thermostat may not trigger to get the oil to the front cooler. Once trick is to put a blanket on the rear hood grill for quicker warmups.
For me, I do not like long idling times on engines, so unless I get a chance to actually drive the car, I am going to stick to cold cranking. Not as long experience as you, its only worked for me for the last 23 years.
Cheers,
Mike
Old 01-05-2017, 11:02 PM   #13
racer959
racer959's Avatar
I let them idle get them up to the right temperature and shut them down. I have an air cooled turbo and water cooled turbo. Never had a single problem.
Old 01-08-2017, 10:38 PM   #14
nine45s
Mine go into Car Jackets after an oil change. Batteries are removed and stored in the basement on tenders. Hope to be moving soon to a place where I can enjoy the toys all year.
nine45s is offline   Reply With Quote
Old 01-08-2017, 11:17 PM   #15
bronson7
Super User
bronson7's Avatar
Interesting, never seen these before.
bronson7 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
WTB winter wheels and tires Terry L GT4 1 02-05-2017 05:10 PM
Any winter driven 997TT's? 9LVN_TT 997 Turbo Forum 42 12-29-2016 04:55 PM
What do you use as winter DD car (if you have real winter where you live)? levd 991 GT3 GT3RS and 911R 60 10-26-2016 06:26 PM
Getting ready for WINTER ric-ko 997 Forum 17 10-18-2016 12:42 PM
Winter storage in trailer? hf1 Racing & Drivers Education Forum 49 10-03-2016 10:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
  • Ask a Question
What's your question?
Send
