993 Turbo Forum 1995-1998
Winter Storage
Old 02-07-2017, 08:35 PM
JPS
JPS's Avatar
Woah. What are those?
Old 02-07-2017, 09:58 PM
nine45s
nine45s's Avatar
Basically a big bag you drive your car onto and zip it up.
Car comes out in the spring looking like it did when it went in.
I've been using them for years.
Old 02-16-2017, 10:56 PM
BrandonH
BrandonH's Avatar
I've had a lot of grief trying to keep the battery charged. I changed from the Battery tender Junior to the charger/tender model, but no avail. I've read on various threads that you need to keep the doors locked to prevent small current drains from messing with the charger's circuitry, but that hasn't worked either. latest symptom was charger red/green lights flashing simultaneously, and ceased charging. Then I got a 9V cig lighter device thinking I'd just disconnect the cables completely and charge the battery disconnected. But the security system freaked out with the 9V trickle, started cycling and flashing quickly. Not sure why mine is so problematic; others seem to have no problem!
Quick Reply: Winter Storage
