993 Turbo Forum 1995-1998
FVD Brombacher – 993 Turbo / GT2 Clutch Parts
Old 12-14-2016, 04:00 PM
Rhonda@FVD
Rhonda@FVD's Avatar
Default FVD Brombacher – 993 Turbo / GT2 Clutch Parts
FVD Brombacher has been specializing in Air Cooled cars in Germany since 1983. We have a vast assortment of German sourced tuning and spare parts for the 993 Turbo and GT2. I will be adding posts periodically so that everyone is aware what we can offer Rennlist Members. Also, we always look out for Rennlist Forum Members with discounted pricing. Kindly contact me via Private Message for the latest promo codes.
Here are a few examples of what we can offer you in the way of clutch parts:
FVD Exclusive Sport Clutch Kit - For Dual Mass (OEM) Flywheel (583 ft/lbs. max.)
List Price $ 1,459 / Member Price $ 1,313 (Member Savings $ 146)
Our FVD Exclusive line of Clutch Kits is culmination of Porsche® Genuine Parts, ZF Sachs Race Engineering GmbH Parts and Motorsports Parts that have been developed to work together without compromise. They offer a silky-smooth release, superb drivability and can handle more torque (583 ft/lbs. / 790 NM max.). This kit is ideally suited for modified street cars and Light / Medium use Track Car.
This kit contains a clutch disc with torsion springs that function as a vibration damper between engine and gearbox. This allows for an effortless release in 1st gear. This kit is suited for daily use and offers a superior street driving experience.
Clutch kit includes:
1 Qty. Clutch Disc
1 Qty. Pressure Plate
1 Qty. Release Bearing
1 Qty. Spline Lubricant
9 Qty. Pressure Plate Screws
Kit Weighs: 15.6 lbs. (7.1 kg)
Tech Tip: When you are planning to install a new clutch, it is a good idea to replace the Clutch Release Fork and Shaft to ensure proper clutch engagement. Our part # FVD 116 999 We also recommend a new Guide Tube 950 116 813 06 for proper installation.
FVD Exclusive Sport Clutch Kit - For Light Weight Flywheel (583 ft/lbs. max.)
List Price $ 1,505 / Member Price $ 1,354 (Member Savings $ 151)
This FVD Exclusive Clutch Kit is culmination of Porsche® Genuine Parts, ZF Sachs Race Engineering GmbH Parts and Motorsports Parts. It has been developed to replace a kit that already has an existing Lightweight Flywheel that does not need to be replaced.
We specifically chose a clutch disc with torsion springs that functions as a vibration damper between engine and gearbox, to give you an effortless release. This kit is suited for daily use and offers a superior driving experience. It offers a silky-smooth release, superb drivability, can handle more torque (583 ft/lbs. / 790 NM max.).
1 Qty. Clutch Disc
Kit Weighs: 16.71 lbs. (7.58 kg)
FVD Exclusive Sport Clutch Kit - With Light Weight Flywheel (486 ft/lbs. max.)
List Price $ 2,100 / Member Price $ 1,890 (Member Savings $ 210)
1 Qty. Clutch Disc
Clutch Hose 993 Turbo - Stainless Steel
List Price $ 52 / Member Price $ 47 (Member Savings $ 5)
FVD Brombacher Stainless Steel Lines for Porsche® are manufactured in Europe and are TUV approved. They consist of a PTFE Teflon® inner liner surrounded by a stainless steel (INOX) braided cover. This construction ensures minimal expansion inside the hose core.
FVD Brombacher has been tuning Porsche® vehicles for over 30 + years now, so rest assured that our lines are a direct bolt on replacement for each Porsche® application.
Clutch Release Fork and Shaft Kit for G50 Transmissions
List Price $ 295 / Member Price $ 265 (Member Savings $ 30)
When you are planning to install a new clutch, it is a good idea to replace the Clutch Release Fork and Shaft to ensure proper clutch engagement. Our kit is comprised of Genuine Parts and contains everything needed to install your new Clutch Kit with Peace of Mind.
Weighs 1.65 lbs (.75 kg).
In order to get these savings please use the current promo code: Rennlist on our online shop: www.fvd.net
We have many, many more clutch kits to offer, a total of 12 in all for each individuals preference!
Our entire range of tuning clutch kits and parts can be found here....
Our entire range of OEM spare clutch parts can be found here...
FVD Brombacher - USA
Contact me directly to get the latest FVD forum member discount!
Rhonda Roxburgh
+1-954-571-2050 x 1
rhonda.roxburgh@fvd.net
Want to learn more about us? Click here...
Old 12-14-2016, 11:37 PM
AC/911's
AC/911's's Avatar
Rhonda Always Delivers Great Service, I've Bought Many Parts overs the Years From Her.
Old 12-17-2016, 05:20 PM
TT Surgeon
TT Surgeon's Avatar
Ditto
Quick Reply: FVD Brombacher – 993 Turbo / GT2 Clutch Parts
