Short shift
Disagree, With the whole kit It make a Good difference, With these cars Still worth good $$, Its worth it.
Just did mine to 2wd, Greatness! Used the New shiftier From FD, Rothsport
http://fdmotorsports.net/964-993-c2-...ort-shift-kit/
Bottom pick for stock look
Had Awd kit til now, Felt much shorter & better than stock, Did not like Bumble underneath in tray though... Hit a few bumps & had to pop back out Twice.
2wd, yes, is just a little better now, need to drive more, in shop doing some tuning.
The worse part of the SSK upgrade is dimpling the center tunnel cover -> it does add a lower spot to the car and there are a few ways to do it (press out a dimple, hammer it out, or cut it out and weld in a dimple). Installation is relatively simple but much easier with a lift - the SSK is a tight fit against the driveshaft for the front wheels, and it needs quite a bit of pressure to put in place.
This is still not a cable shifter though, it's still fairly long but with the SSK and Goldenrod, it improves the feel and reduces the stroke by 30% I believe. Adding the Fister transmission mount is a bit more subtle, it does tighten things up but depends on how bad your mount was to begin with. I now get a lot of gear lash noise (with a RS flywheel and GT3 clutch disk so no dampening there)after adding the transmission mount, I don't mind it but its pretty noticeable, especially when the transmission is cold.
Cheers,
Mike
Cheers,
Mike
