Car won't idle, starving for fuel issue??
Hi there, Been a while since on the thread but after the car was working great a week ago it now won't idle and seems to be starving for fuel. I can keep it running by revving it but is sputters and knocks and make odd noises and then slowly cuts out after not idling properly. It also smells flooded, probably because of revving it to keep it running.
Any ideas on if you have experienced this. I was thinking maybe a fuel filter or bad gas but it ran fine for 3/4 of a tank and I have not refilled yet. Is the fuel filter easily changed. I saw it next to the airbox yesterday when I had the intercooler off but am not sure if its an easy change (most things aren't)
Need to get it sorted out for Rennsport Reunion in a few weeks in Monterey. Hopefully there is an easy fix so I can avoid taking it in for service.
Thanks for your help guys.
Technical Guru
