993 Turbo Forum 1995-1998
Recommended Tire Size for 18X8.5 and 18x11 ET 56.
Old 06-10-2016, 11:18 AM
simonheo
simonheo's Avatar
Default Recommended Tire Size for 18X8.5 and 18x11 ET 56.
Hi,
What size tires would you recommend for BBS LM 18X8.5 and 18x11 ET 56?
F:235/40/18
R: 295/30/18
Thank you.
Old 06-10-2016, 05:02 PM
AC/911's
AC/911's's Avatar
315/30/18 Rear, Then you'll get same diameter as front & a .5' wider...
Might still need a small rear spacer for turbo.
Old 06-10-2016, 08:43 PM
simonheo
simonheo's Avatar
Thank you.
Simon
Old 06-10-2016, 09:42 PM
AC/911's
AC/911's's Avatar
With the extra .25'' going out on rear should be a Perfect fit, stock is 10'' 40et.
https://www.1010tires.com/Tools/Whee...et-Calculator#
Old 06-11-2016, 04:58 AM
Basal Skull
Basal Skull's Avatar
Depends on what spacer you are using, 315 would be tight if your final offset is 33 (stock would work fine with 33 offset)
Old 06-11-2016, 04:14 PM
AC/911's
AC/911's's Avatar
No spacer needed, .25'' is tire, offset calculator says retracted 3mm, Tire will make up for that plus a few mm's.
Quick Reply: Recommended Tire Size for 18X8.5 and 18x11 ET 56.
