Instrument Cluster Power
I have been having intermittent power to my entire instrument cluster. The car will start & run normally, but often has: No fuel, Oil pressure, Tack or Speedo. All dead. Then sometimes they'll all just start working again.
The 993 Board had a post or two with one possible solution being an R11 relay. Has anyone had this problem?
Sadly wiggling all of the fuses and relays did not fix the problem.
