993 Turbo Forum 1995-1998
Wanted: direct replacement aluminum rotor hats
Old 01-07-2015, 10:00 PM
Ag02M5
Ag02M5's Avatar
Default Wanted: direct replacement aluminum rotor hats
It seems these have been made by a few different people at different times throughout the years but I am having difficulty finding a set.
If anyone has a set laying around or knows where some could be procured...
Cheers.
RT
Old 01-11-2015, 01:28 AM
budge96
budge96's Avatar
http://www.ebay.com/itm/porsche-993-...44831e&vxp=mtr
Old 01-11-2015, 12:18 PM
Ag02M5
Ag02M5's Avatar
Appreciate the heads up but those are the factory steel hats. Looking for some weight savings.
Cheers.
Ag02M5
Ag02M5's Avatar
Also I found a place that may make some but needs to make a run of them. If anyone else might be interested, please chime in here.
Old 01-20-2015, 02:38 PM
Fortuna
Fortuna's Avatar
Cheers.
RT
I should be the kit. I bought it two years ago on Ebay.
I think I am ready to sell.
$ 250 + shipping
Sergey
Old 01-20-2015, 03:01 PM
Ag02M5
Ag02M5's Avatar
Pm sent. Thx.
Old 01-26-2015, 03:28 AM
Fortuna
Fortuna's Avatar
foto
Old 01-26-2015, 11:02 AM
Ag02M5
Ag02M5's Avatar
Hi Fortuna. Thanks for getting the pics but those are the hats from the original brake disks in steel.
I am looking for a lightweight aluminum replacement.
Cheers.
Old 01-26-2015, 11:55 AM
OverBoosted28
OverBoosted28's Avatar
These guys will build the hats for you. Just give them the specs and they'll build the hats and rotors
Old 01-26-2015, 04:28 PM
Awdnut
Awdnut's Avatar
Default GiroDisc P93T replacement front rotor
I have a set of P93T front replacement rotors from GiroDisc on my car. It does have the aluminum hat but I don't think it will fit the original rotors. Compared to the weight of the OEM front set-up which is about 20.2 lbs. The GiroDisc front rotors (with the aluminum hat) is about 16lbs.
HTH,
Old 01-26-2015, 04:49 PM
Ag02M5
Ag02M5's Avatar
Thanks for the inputs.
Coleman wants $275 per hat to make them.
I like the Giros alot but don't think I could stand looking at slotted front and drilled rear. Just out of curiosity, how many bolts does the Giro rotor have? If 10, then I bet it is sized pretty close to the original.
4 pounds per corner is some good savings for sure.
Old 01-26-2015, 06:40 PM
Awdnut
Awdnut's Avatar
Slotted or drilled, you can specify what you like with Giro
Old 01-30-2015, 01:22 AM
Ag02M5
Ag02M5's Avatar
I did talk to Girodisc...need 5 sets for them to do the drilled. Any takers?
Old 01-30-2015, 05:01 AM
Fortuna
Fortuna's Avatar
Maybe you are looking for such a hat?
Old 01-30-2015, 11:06 AM
Ag02M5
Ag02M5's Avatar
Yes Fortuna. Something like that.
Quick Reply: Wanted: direct replacement aluminum rotor hats
