993 Turbo Forum 1995-1998
Engine out
Old 10-17-2014, 09:02 PM
Rick GT3
Rick GT3's Avatar
Default Engine out
engine was remove from my 993tt for replace gasket due to oil leaks. Now is time for clean up. cleaning will continue tomorrow with engine, transmission and underbody.
also will replace power steering belt, now that the engine is out, install new transmission mount and Wevo engine mounts.
Old 10-18-2014, 11:59 AM
OverBoosted28
OverBoosted28's Avatar
Check the 993 forum regarding the WEVOs
Old 10-27-2014, 08:13 PM
doublecabmel
doublecabmel's Avatar
I love these threads
Old 10-27-2014, 10:29 PM
Rick GT3
Rick GT3's Avatar
all new valve covers gaskets had been installed,also installed new spark plug NGK, Porsche oil filters (2) & Mobil 1 20W50 oil, all 5 S-CAR-GO hoses installed, new power steering belt, Wevo engine mount, transmission mount replaced, Crane LX91 730-0891 coil.
engine and transmission also were cleaned.
will post pictures...
Old 10-28-2014, 12:07 PM
Mike J
Mike J's Avatar
Nice!
Are you using V-Twin or regular Mobil 1?
Cheers,
Mike
Old 10-28-2014, 01:33 PM
OverBoosted28
Don't 4get to take care of your sagging foam insulation. Just use a 1 1/2"-2'' strip of aluminum from Lowes. Super easy to do, especially w motor out.
Old 10-28-2014, 07:39 PM
Mike J
Mike J's Avatar
Or just get rid of it!
Old 10-28-2014, 09:01 PM
Rick GT3
Rick GT3's Avatar
V-Twin 20W05
Old 10-28-2014, 09:11 PM
OverBoosted28
Yep, when I drop the motor, I'll be ripping mine out.
Old 08-07-2016, 10:18 PM
Guy
Guy's Avatar
Edit. Darn mobile!
Old 08-12-2016, 06:06 PM
TheBen
TheBen's Avatar
You could get the pad keeper from David etter for the sagging sound pad...
Quick Reply: Engine out
