turbo pipe or hose
turbo pipe or hose
Question for the expert out there. Thinking replacing the tubor charger due to oil leak. While i am there are there any hose or oil line or clips i need to replace.? I have check the parts diagram but can only see oil lines. surely there must be other hoses for air flows.
parts number or name will be helpful.
thanks in advance.
thanks in advance.
Everything is reusable - the only hose that gets some wear is the pressure hose from the turbo to the intercooler, primarily due to removal of the intercooler - the ends of the hose get worn. Sometimes you get corrosion on the turbo studs because of the all the heat cycling, and rust on the heat shields. That is about it, just inspect the parts as you take them off and replace what is required.
Cheers,
Mike
Cheers,
Mike
