At the track , having some fun !
And you need your intercooler surround, did you get the andial one when you puchsed the cooler (or modify the stock one or make your own!). From the tests I've done it makes a difference!
The old one will not fit without some mods, the inner lip needs to be cut out and the back tabs for the fasteners need to be slightly repositioned or redrilled. Find a spare to can modify or rig something up on your own! Can make one out of aluminum, I've made a couple, will snap a pic when I'm finished my gym routine.
The stock (or modified for andial cooler) shroud is pretty heavy. I made one out of thin gauge aluminum, contoured some to have the intakes off the gt2 wing blow on the end tanks. I had made one previously so the intake was routed to the air box but that threw a MAF (impossible reading?) cel and was told by our local guru that (the cel would happen - he was right) it was better to route the intake to blow on the end tanks where it is hottest, so that's what I did. (I have the back part of the shroud is actually glued on the inside of the lid).
