Price reduction for Andial 3.8
Happy 2014. New price for the Magnifico El Guapo.
Best offer over $135K takes him home.
One of Ninteen Certified Andial 3.8 Liter Twin Plug Conversions.
Please see hi-res Photo Gallery
1997 Andial 3.8 Twin Plug Twin Turbo Specs
Andial dual program 3.8 twin plug
Andial intercooler
Andial LW clutch and flywheel
Andial sport cats
Custom "Big Oval" muffler bypass
Forge diverter valves
RS short shifter
RS engine mounts
Cargraphic additional oil cooler
Front and rear RS adjustable sway bars
14 inch front brakes
Cargraphic active front brake ducting
RS rear brakes
GT2 uprights and tie rods
PSS-9 suspension
Corner balanced and aligned
12.5 x 18 and 10.5 x 18 BBS E28 wheels
335.30.18 and 265.40.18 Michelin PS2 tires
Carbon fiber rear decklid
Fiberglass wing with "Guerney Flap" mounting holes.
Hand laid fiberglass fender flares
OEM Euro GT2 front end bodywork
Ruf A-pillar fairings
Sport seats
Yellow seat belts front and rear
Carbon fibre interior
Leather air bag cover
Car History
Here is the information I have been able to glean about the car.
This highly optioned car was purchased in the Chicago area by car collector John Pizer. He immediately had it flat-bedded to the Andial facility with only delivery miles on the car.
The full Andial 3.8 liter twin plug conversion was performed at an estimated cost of 55-60 thousand dollars.Andial Twin Plug
A few years later the car was purchased by collector Amir Fahti in Calabasas with around 4000 miles on the clock.
In 2007 I purchased the car from Mr. Fahti with 27,181 miles on the clock. Unfortunately Mr. Fahti had lost the build sheet on the car. Andial confirms that this is one of the 19 certified 3.8 liter twin plug conversions, of which only 17 remain. Andial Registry
Over the next few years I had Michael Schatz MKS Performancein Camarillo fettle the car into tip top condition, replacing the front differential, viscous coupler, clutch accumulator, steering rack and installing a set of GT2 uprights and tie rods, new hood shocks, breeze constant torque clamps on the intercooler hoses and forge diverter valves. I removed the k40 radar detector and installed functional front brake cooling ducts and a larger Cargraphics oil cooler. I installed yellow rear seat belts to match the front seat belts. Finally, a complete corner balance and alignment and rake was performed.
In 2011 elected to make this car into my vision of the ultimate street version of a GT2.
I contacted 1998 IMSA GT2 champion Jochen Rohr who generously supplied me with the rear wing and carbon fibre deck-lid plus the BBS wheels he had left over from that race team. I sourced a brand new OEM European narrow-body front bumper and some hand laid fender flares and commissioned Ed Palmer at Kundensport to perform the conversion.
The car is everything I could have hoped for. It looks fabulous in my eyes. It rides very smoothly. The GT2 uprights and tie rods have minimized bump steer and the ride is not harsh in any way but it still handles brilliantly. The paint is exceptional. It is the best rding 993 I have ever driven. I clay barred it using Final Detail as the lubricant over a weekend and it presents very well indeed. It is nearly impossible to put the car cover on by yourself because it keeps shooting off as the paint is so smooth. Obviously the car is brutally fast but also very tractable. The larger pistons on the RS rear calipers match the 14 inch front brakes very well. A minor service and detailing was performed last week.
With the passing of Arnold in 2011 and the purchase of Andial by Porsche Motorsports in 2012, I believe no more of these cars will be built and a stellar chapter in Porsche history has closed.
Nits to pick:
There are a few rock chips on the front.
The front tires can rub if the wheel is turned to full lock at parking lot speeds.
The Thielert dual program street/race gas ecu is a bit unsophisticated and no longer supported. They need two revolutions of the crank to start the car and can run a little rough just off of idle. It occaisionally becomes “confused” and can cough and spit for a bit. Then it remembers it’s manners and clears up. It is not foolproof. You need to make sure you have 100 octane race gas in the tank before switching to the race gas setting or damage could occur.
There is a more modern Andial aproved ecu available, but you lose the dual programming capabilities. Having the "psychopath switch" under your left hand is just too much damn fun! As a result I elected to keep the dual program ecu and live with the very minor flaws.
For more information email me at scottmellor@karenschiltz.com
Andial intercooler
Andial sport cats
RS short shifter
RS engine mounts
RS rear brakes
PSS-9 suspension
Sport seats
Car History
Nits to pick:
Truly a stunning specimen. Seriously. An absolute beauty.
The only thing keeping me from grabbing this is the color. Sadly, it doesn't work for me. A beauty, nonetheless!
Good luck with the sale.
That is the Andial Kneecap Boost Gauge.
It's practically useless, since looking down at your left kneecap under full boost is like facing a charging rhino blind-folded.
