position of the rear turbo badge
Hello to everyone!
I need a little help:
The rear turbo badge was removed due detailing but was forget to mesure it's correct position ( I know it's a stupid mistake, but it just happened)
I called the P service but they don't have any drawing about it.
Does anybody has info about the factory position of the rear badge? Many thanks for the help in advance!
Well, my wing is sitting beside me in my den... what measurement do you need. The center 'r' (ie half way up the vertical part of the 'r') is the middle/center of the wing side to side. The very top of the 'r' is 8.5cm from the lower section of the wing. Clear as mud?
first of all, many thanks for your fast and useful reply! The horisontal position was clear, however i would need a little more help about the vertical position:
How many mm is between the bottom of the "r" and the lower horisontal kick of the wing?
thanks for your answer in advance!
Arpad
I don't have any parts in the kitchen but have thought about using the dishwasher to clean some parts... I tried using the oven to bake on high temp paint for exhaust tips but found the BBQ worked better.
I don't have any car parts in the office, just skulls.. Will have to wait til I get home for the measurement !
