993 Turbo Forum 1995-1998
Bump Steer + RS Uprights
Old 08-30-2016, 01:36 PM
  #46
darrendeguire
darrendeguire's Avatar
Wish this upgrade was legal in club racing!
Old 12-01-2016, 07:09 PM
  #47
TurboIXXI
TurboIXXI's Avatar
Yep, I've been waiting for RS uprights since August. No luck finding these anywhere!
Old 05-24-2017, 06:09 PM
  #48
DRPM
DRPM's Avatar
HELP
Does anyone have advice and or a picture of the drop link installed with a AWD using the RS uprights.
I'm using a Tarret drop link (C shaped as I have AWD) and having some interference issues with the flexible brake line.
thanks
Old 05-25-2017, 11:44 AM
  #49
OverBoosted28
OverBoosted28's Avatar
Get the Elephant Racing AWD or OEM links. The Tarretts have had clearance issues on AWD cars.
Old 05-25-2017, 08:50 PM
  #50
DRPM
DRPM's Avatar
Are you using the ER links with RS uprights?
Old 05-27-2017, 04:45 PM
  #51
OverBoosted28
Originally Posted by DRPM
Yes, I presently have the Elephant AWD front drop links. And they're installed on the RS uprights to H&R sway bar. Others in the past have had issues with the Tarret links, not having enough curve, to maintain clearance. The ERP drop links are really stout, and the ends can be replaced, if need be.
Old 06-01-2017, 04:14 AM
  #52
911PERVY
911PERVY's Avatar
Never heard of the brake hose being an issue, the Tarrets dont clear the drive shafts due to not enough curve, I tried but went back to OEM. GT2 uprights with H&R like OB has.
Old 06-01-2017, 09:52 PM
  #53
DRPM
DRPM's Avatar
I'm putting in the ER drop-links
Old 06-02-2017, 09:39 PM
  #54
OverBoosted28
DRPM you'll be happy with em, I am :-)
You can actually remove any preload also
Old 06-03-2017, 11:22 AM
  #55
DRPM
DRPM's Avatar
Thanks.
Indeed looking forward to finalizing the set up.
Old 06-13-2017, 06:24 PM
  #56
OverBoosted28
Thanks.
For those of you, who may purchase the ER drop links, make sure you get the top rod end set right. The top rod end, which goes into carrier, has about 35° of travel. If the drop link is centered (in this plane of travel) the link MAY come into contact with CV boot/dust cover. What I did was turn rod end to one end of its travel (closest to hub) and tightened lock nut. This way IF the drop link moves at all, it'll still clear boot. Already called Chuck at ER, and let him know.
Old 06-13-2017, 09:33 PM
  #57
DRPM
DRPM's Avatar
Thanks, will check it out!
Quick Reply: Bump Steer + RS Uprights
