993TT Misfire- Help
993TT Misfire- Help
My car is idle ling rough and misfiring, time to change a few things:
planning on changing:
Distributor Cap
Spark plugs - F5DP0R Bosch
Iginition Wires
Fan Belt
What else should I change while at it? Engine Temp Sensor, oil temp sensor?
Lastly where do you guys buy it from? Pelican? Dealer? I have a shop discount. Thanks for your input.
Distributor Cap
Iginition Wires
Fan Belt
Agree with your choices, although you may want to consider the slightly colder FR6LDC plug.
You should also change the ignition rotor.
Cylinder head temp sensor has been known to cause some issues.
Fan belt and ignition wires, sonnenoemporscheparts.com (the pelican wires won't fit without modification)
For the plugs, dizzy cap/rotor: amazon, especially if you have amazon prime. Best prices, and you know you are getting authentic parts.
yes.
For instance, bosch dizzy cap in bosch box at amazon...$53 free shipping, no tax.
Dizzy cap at dealer, $153...$99 at online parts sources.
btw, my bad, its sonnenporscheoemparts.com
no problem. The dizzy cap and rotor are a piece of cake. Ignition wires suck if prior replacement was not done with an eye for future service. Plugs aren't bad except for number 6 by the ps pump.
Belts are finnicky but not too bad. Haven't done CHT.
Thanks, you mind telling me about the rotors? Cant seem to find the one on Amazon. sorry.
or
http://www.autohausaz.com/search/pro...ibutor%20Rotor
az autohaus is another good choice for parts.
http://www.amazon.com/Bosch-04216-Ig.../dp/B000BZHXQS
or
or
man I cant believe this is so cheap!
Received 5,388 Likes
Godspeed, how's your MAF sensor? Not cheap, if it needs replacement, too. Just a thought.
RL Technical Advisor
Bosch heat ranges are hotter as numbers go up. A 6 is hotter than a 5.
NGK heat ranges are the opposite; as the numbers go up, the plugs get colder.
JMHO, but I would not use a Bosch 6 plug in any Turbo.
In these threads, you didn't mention a problem with the 6 plug, and it was recommended by Kevin at UMW.
https://rennlist.com/forums/993-turb...-question.html
https://rennlist.com/forums/993-turb...gs-to-run.html
fwiw, i run the FR6 and the plugs have looked fine when I've checked them. Nothing to indicate that they were too hot a plug.
You would not start replacing sensors, etc. just yet. I would do a basic tune-up first, and then if you still have issues, continue on with diagnostics.
For instance, I would do the plugs/rotor/cap/belts/filter's first. The drive it. Replacing spark plug wires is not a scheduled maintenance item (on the Porsche literature) and i only replace them when needed. The turbo wires last longer than the NA cars, they are on the upper (cooler) side of the engine. None of the wires run weird tight corners near exhaust systems.
Be careful with the belts, use Porsche brand belts - there have been issues of misfire codes being caused by other manufacturers belts. Also, is your car picking up any misfire or other codes? Code may exist without the CEL light being lit, you may want to check.
How many miles on your engine? Other maintenance items is to clean the ISV (they seem to run a bit cleaner on Turbo's though), and if your mileage is high enough, you may want to consider cleaning the injectors. You need to pull them and send them out to be cleaned. On the cars I have done this with, its rare to have all six perfectly flowing, and I have found cases of partial plugs causing spray issues on 3 out of 6.
Cheers,
Mike
Cheers,
Mike
