993TT Misfire- Help
#31
Thanks for the Great advice!
Switched the coils and car runs 90% better. It appears my coil was no good. It also appears I need to upgrade to a CD system. Even though she hits boost she still breaks up which tells me it most likely is blowing ofF the spark after boost comes in. She starts breaking up after 4500 rpms or so. My tech says I could either gap the plugs closer or get an MSD ignition system. I will look into your crane system. Thanks!!
#32
Updates!
Changed the plugs this weekend, I'ts like having a root canal but I did them.
Car is a beast!!! Holy smack! 1.4 Bars all day on Race gas. I also noticed car oil gets really hot quickly and gets heat soaked. After 2 or 3 runs with these GT3076's engine oil temp is past the 1/2 almost 2/3 mark and hangs up there. I think I will add a small front mount oil cooler to help. Any suggestions? Thx
#33
You have the fan bypass installed? This is so the oil cooler fan is running at high speed before you even get onto the track. That helps a bit getting ahead of that heat rush. But that cooler only has so much capacity, so the second oil cooler makes perfect sense.
Cheers,
Mike
Cheers,
Mike
#34
Nope, I don't thats a great idea. I think I will add a toggle switch to turn it on automatically for spirited runs. How do I bypass the ECU?
Cheers,
Mike
Cheers,
Mike
#35
I did three this weekend alone - I need to update the procedure on pcarworkshop, but its essentially close. You can add a switch to your central console, you are fooling the CCU (the climate control unit) on the dashboard, which controls the high speed fan circuit, into thinking the temp sensor on the oil cooler has triggered. The sensor wire is G12 (Green/Black) wire on the larger connector on the CCU -> basically it goes open circuit to trigger the fan, so you put a switch in circuit that you can open circuit it manually. Very handy in heavy traffic, hotter days, or track days.
See this procedure:
http://www.pcarworkshop.com/index.ph...verride_Switch
I really need to update it, its very dated, but it does work.
Shoot me any questions if you have any.
Cheers,
Mike
See this procedure:
Cheers,
Mike
#37
There is not such thing as to much oil cooling(same goes with intercoolers) on air cooled cars, try to smack in the front the most cores you can, I'll give you an example of what you can shoot in there, one right stock unit, one center mounted unit (B&B unit works),one left side unit (FVD,RUF,etc),this should give you more than enough cooling capacity.,cheers,Sonny.
#38
#39
Lean condition at Idle.....
Sorry to reignite my own thread but need some info from the gurus here....
The CEL code I get is (P0130 ) O2 Circuit Bank 1 Sensor 1, but I just replaced all 02 sensors for new ones and still get same code.
After installing my protomotive headers and T04 turbos (which I am replacing with GTX3076 soon) I have developed a Lean condition at idle. I know many will tell me it's a vacuum leak etc. I have searched and can't find it, every hose seems plumbed correctly. I might attempt a smoke machine soon unless someone could tell me how to test the system pressurized. The car drives perfectly fine cruising but any minute I stop and idle my A/F meter goes of the charts into Lean. I then start popping and car does "phut" "phut" sound.
I bought the durametric cable thinking it would help only to find out that I believe due to the Protomotive tune it might have blocked of any live data or reading capabilities with the tool. I can't get into the ECU and do any logging at all. Has any one experienced this?
Lastly, I thought it was the MAF, so I disconnected it since the car will revert to the ECU limp map and car still idle'd lean.. This eliminated the MAF possibility I think.
Any help is appreciated, don't know what else it could be, I have read so many other threads from people saying to check the oil cap etc, others say to check the CAM timing but I cant do that due to the blocking of the Protomotive tune in the ECU.
#43
Do you know what's FP at idle? I will google it. Thx
#45
Do you know what FP at idle should be? Googled a few posts and should be around 47-50psi... Let me know if it sounds about right. Thx
