993 Turbo Forum 1995-1998
993tt Radio Upgrade w/ Nokia HIFI amp
Old 01-30-2013, 01:50 PM
My1st911
My1st911's Avatar
Default 993tt Radio Upgrade w/ Nokia HIFI amp
Gentlemen,
Would you happen to know if this harness will allow me to upgrade to an aftermarket stereo (I'm considering the toronto 420bt) and retain the Nokia HiFi amplifier? I'm trying to avoid modifying the oem wiring.
http://www.discountcarstereo.com/HRC-POR.html
Thanks for your help!
Old 01-30-2013, 02:10 PM
Felix
Rennlist Lifetime Member
Felix's Avatar
From (hazy) memory a radio with DIN connectors such as these will be plug and play
Old 01-30-2013, 02:27 PM
x50type
x50type's Avatar
From the plethora of wires coming out of the back of this radio you will probably have to cut off the OEM plug/s and crimp to the OE harness.
Here's a photo the OE radio connectors.
Old 01-30-2013, 02:35 PM
My1st911
My1st911's Avatar
Gah, that's a lot of wires. The photo you posted is of a CDR-210 w/ the Nokia hifi amp?
Old 01-30-2013, 07:03 PM
x50type
x50type's Avatar
It's the original 1995 CR-1 radio with Nokia under seat amp.
FYI the connecting plug on the amp is 25 pin using the OE wiring harness -- yes, lots of wires.
Old 01-30-2013, 07:13 PM
My1st911
My1st911's Avatar
Ok, thanks very much. I need to just go ahead and pull my CDR-210 to see if the wiring differs.
Old 01-30-2013, 07:41 PM
Mike J
Mike J's Avatar
Its totally different than the picture above (posting #5). Power/control is the black connector, speakers the yellow connector, and aux input is through another connector which is not shown. That is only used if you have the CD in your trunk or an iPod interface. The connectors you looked looks correct to attach to the factory harness:
Cheers,
Mike
Old 01-30-2013, 07:48 PM
My1st911
My1st911's Avatar
Great! Well that makes it simple then. I won't even need a separae aux connector b/c the toronto 420bt already has a couple of usb connectors. Thanks guys!
Old 01-30-2013, 09:15 PM
x50type
x50type's Avatar
OK -- Let's know how you get one -- hopefully it's plug and play
Old 01-31-2013, 08:00 AM
dr jim
dr jim's Avatar
I had a Blaupunkt Toronto in my '97, and it was definitely plug and play with the Nokia Hi Fi amp.
Jim
Old 02-03-2013, 05:08 PM
TheBen
TheBen's Avatar
How did this work out? Interested in getting a Blau myself.
Can the display be changed to Amber to better match the interior lighting?
Old 02-05-2013, 12:38 PM
dr jim
dr jim's Avatar
The radio worked out fine in terms of installation and operation. I didn't love the look (in my opinion too modern and kinda cheap looking) or the sound (bright and thin) with the stock amp and speakers, so I changed it out for a Becker.
The display color can be changed. However, it's been a while since I had this radio and I don't recall if amber is one of the choices. If I recall correctly the color options were in the blue, green and red range, as well as black and white.
Jim
Old 02-18-2013, 03:01 AM
Baneking
Baneking's Avatar
Jim
Which Becker did you put in?
Pardon the ignorant question, did 96 have the Nokia amp? I'll have to go to the other house and check- was it under the passenger seat? Reason I ask is I saw some later models with some amp controls in the drivers door console. Wasn't sure if that was an add on.
Old 02-19-2013, 08:44 AM
dr jim
dr jim's Avatar
I put in a reconditioned Becker Traffic Pro. I got it from Becker Autosound.com. Here's a link: http://www.beckerautosound.com/plug_...e%20index.html
The '96 TT came standard with the Hi Fi option which includes a Nokia amp under the front passenger seat. The controls in the driver's door arm rest are part of the Digital Sound Package - an optional factory upgrade. The Digital Sound Package has a Nokia amp under the passenger seat (as far as I know it's the same or very similar to the amp in the Hi Fi option).
Jim
Old 02-19-2013, 11:15 AM
Baneking
Baneking's Avatar
Jim
Thanks! I'll check them out. Had seen their website before. Good to hear they are reputable.
Quick Reply: 993tt Radio Upgrade w/ Nokia HIFI amp
