Aquamist water/methanol injection
With the extreme ambient temperatures this summer, I decided to buy an Aquamist HFS-6 system for my 993TT, which has UMW "GT1" turbos and tuning (~1.0 bar boost). I use my car for mostly for track days, with occasional street driving. I run 100 octane at the track and 91 on the street, and basically I'm looking for extra insurance and minimizing knock sensor intervention rather than a more aggressive tune.
Searching the forum, I'm surprised at how few have tried water/meth injection. I found a few posts from people who had projects underway, but I didn't find any information about completed installs.
So, anyone running Aquamist or another water/meth injection system? I'm hoping to learn from someone who's already done it before I dive in.
ive got it on my old gt2 evo racer and now a cayman with the gt2 engine. it works great and my inlet temp went from 45/50 deg c where boost dropped off throughout the race to 30/35 where it holds 1.5 bar for 30 minute races. dont know how my inlet temps compare to others as my sensor is in the carbon plenum where it meets the top of number 6 throttle body as i run 6 throttles with 2 plenums. aquamist works though, i have a master switch then a boost sensitive switch that you can adjust. i preset mine to 1 bar, as the point that it injects. i run 50/50 methanol/water. any more questions, just ask
regards mark
regards mark
I've been running water meth for the last year. My set up comes on at .6 bar. Data logs prove the system works very well at keeping temps down. I fab up a custom tank in the front bumper with the fill next to the gas cap.
I have the HFS 3 with a custom fuel cell tank up front and run 50/50 meth (VP racing methanol not washer fluid) and water. The more meth the greater the cooling as well as the octane but your AF will get lower (richer). My car is not tuned for it and I use it for IAT cooling only. On average it will bring my AF down from the low 11's to the high/mid 10's at WOT.
My car is a built 3.6 with tial A28's and I run two .1 aquamist knozzles and will go through about 2'sih gallons of fluid in a 30 min track session. They are plummed in the center channel of the IC so there is ample time for the fluid to atomize (this is how it cools the IAT). It runs on injector duty cylce so you just have to tap into an injector line and your're done. You can change the parameters on the control board and watch with the flow gauge to fine tune it to your flow needs. Its very easy. With the HFS 6 you can get really fancy but unless you tune the car for it (our ECU's aren't smart enough to really take full advantage imo) then you can save yourself time and money and get a simple system.
Only get aquamist and I only recommend Jeff Howerton at Howerton enginnering. He built my tank setup and here is a pic off his site. No affiliation just a happy customer
http://ec.cdn.cincopa.com/Porsche+Is...AQ6X-qJ&as=mp3
When you open the trunk all you see is the CF top so it looks nice, the fuel cell for piece of mind if in a bad crash and I can still fit a couple cases of beer in there. Honestly a plastic tank is fine but I tend to go overboard sometimes.
Let me know if you have any questions
haha so few here have tried it. It's turbo 101 on most platforms.
http://howertonengineering.com/
I think I'll go with one of his twin tanks if I can make it fit alongside my cool suit cooler in the trunk.
Doing some quick jetting math on my setup (44 lb/hr injectors @ 3.8 bar, 1.25 bar max boost), it looks like I need a couple of 0.8mm nozzles. My initial assumption on nozzle placement was near the intercooler inlets. Any particular reason you chose the center channel of the intercooler?
Spartan, thanks for the info, especially the Howerton tip. His custom work (tanks, etc.) is really nice, and there's lots of good tech info on his site:
I used .8's and was not going through enough fluid. Worked with Jeff and the 1's were the ticket and I'm happier with that setup. Discuss your setup with him and start out small and see how much fluid you use. Maybe 1's are better but you only have enough fluid for a 30 min session using .7's or 8's. All depends on your tank size and tracking habits.
Assuming its an aquamist then there is not enough flow from one of many reasons. Guage should show full flow the second under WOT (actually it should be setup to flow almost equal between throttle position and flow rate but lets not get picky) since its based off injector duty cycle not boost. If you don't flow enough fluid you don't make a significant difference in IAT's
