Removing the little panel behind the spoiler
I think you're pointing to the rear decklid itself. The rear wing is attached to the decklid which, as far as I know, is removed at the hinges.
Is your car slate grey? More pics please.
Are you talking about the rubber seal? I don't think it's glued. You should be able to carefully pull it right off the tailbase. The rubber piece is molded with raise surfaces that insert into slots in the tailbase.
After futher review I guess you're talking about the deck area that the rubber seal mounts into. I would think the tailbase was made from two pieces (inner and outer) and joined together into one piece for structural integrity.
