993 Turbo Forum 1995-1998
How To Replace The Cylinder Head Temperature Sensor?
Old 05-14-2012, 02:22 PM
utahrock
utahrock's Avatar
Default How To Replace The Cylinder Head Temperature Sensor?
I asked on the 993 forum, but thought I'd post here also in case there are different considerations for the Turbo. I've got a P117 code, bad cylinder head temperature sensor. I know it's not a fun job, but it's barely drivable so I may not be able to get it to my mechanic. If I end up changing it, do you access it from the top or from the bottom? Thanks for any insight!
Old 05-15-2012, 03:34 AM
WingChun
WingChun's Avatar
It looks like this has mostly been covered on the 993 forum, the only thing I think that wasn't mentioned was the fact that you may well have to move the left side turbo plastic air intake tube out of the way to gain access to the sensor.
Old 05-15-2012, 07:50 AM
No HTwo O
No HTwo O's Avatar
Kevin has advised (warned) us several months ago, that these are going to start showing their age, and need replacement.
Old 05-15-2012, 01:38 PM
Kein_Ersatz
Kein_Ersatz's Avatar
Add to the "while you are in there list" I guess.
Old 05-15-2012, 08:32 PM
utahrock
utahrock's Avatar
Yes, indeed. The problem is you can't take it all the way out. But you can move it just enough that you can get the job done, while cussing German engineers who didn't have time to think about making it easier to replace parts.
Old 05-16-2012, 02:25 AM
WingChun
WingChun's Avatar
It does come out, got mine out cos it had loads of oil in it, but at the time I was doing the valve lifters and chain cover gaskets, so the engine may have been lowered a touch. The risk of damaging the tube it is pretty high though!
Quick Reply: How To Replace The Cylinder Head Temperature Sensor?
