Ceramic Coating
Ceramic Coating
Any reccomendations for shops that do ceramic coating of exhaust tips?
Also, does the coating add any type of thickness that will impact the tips reattaching properly?
Thanks.
Thanks.
Funny. I just sent Darin my Turbo's bypass pipes on Monday afternoon. I am going to have them ceramic powder coated in Black Velvet. No more polishing the chrome tips.
I also sent him my metal license plate frame to have either powder (not ceramic) coated in the same/similiar black velvet color, or Arena Red to match the car. I thought this was a nice little "attention to detail" to make sure the back end looked its best.
I wonder if the tips will run any "cooler" to the touch?
Here are his color choices for the ceramic coating:
Interesting subject indeed. I don't know about performance gains but the exhaust fumes will flow faster if kept cool. Lot's of people ceramic coat the entire exhaust systems inside out. The tips are often neglected and they do get very hot.
How scratch resistant is the ceramic coating? I've heard that you prolong the life of the exhaust system by doing the ceramic coating so I guess it preserves the metal against rust?
I think the black TT mufflers on FDs homepage are mine as I did mine like two years ago. I'm super happy with the product, just wondering about the coating.
Also, I'm doing a fair bit of polishing on my SS big ovals. I've been thinking about doing them in the "cermakrome" ceramic finish. Will they then be easier to keep clean? Just rinse with soap and water? Scratch resistant? How would you compare the visual appearance of the cermakrome vs. the OEM polished tips? Will the "crome" finish last? I think the shine of polished steel will be tough to beat. I understand if you coat the tips in black, then you won't have to worry about polishing but I like the stainless look .
Viggo, for tips if you like the polished look I would not ceramic coat them. The Cermachrome finish does not look as shiny as polished tips. It looks more like polished aluminum. If that is the look you are going for, then that would be ok, but if you like the "chrome" polished look, keep them polished. Ceramic coating is paint, so it will scratch if you put a lot of pressure to it. Once it is heat cured, it is pretty tough though.
What are people's thoughts on ceramic coating the cats? - They are the most visible when you are under the car and are there any benefits? They can really start to look bad after awhile on their exterior.
The ceramic coatings keep the heat in and are much cooler outside the pipes because of this. (When i say cooler, definitely dont touch them when the car is running, they are still hundreds of degrees, but just less hot on the outside because of the coating then regular piping).
I am just wondering how a ceramic coat and noise related modification might effect the value of the car. (I know everybody hates that question) Also the Bischoff mufflers are virtually impossible to find. I guess if my time horizon is quite long it shouldn't or should it matter? I would be inclined to ceramicoat everything except the turbo.
Administrator - "Tyson"
