Wheel Balancing with Spacers.
Switched out my stock rims for a set of RUF 18s yesterday.
Stock
RUFs
It definitely changes the way the car looks and I'm very happy with them.
The new tires are Michelin Pilot Sports in stock sizes with maybe 1000 miles on them. On the drive home I noticed a vibration ~75 mph. I called the PO and asked if he had noticed a vibration when he had them on his C2. He said they were totally smooth.
The only difference between the installs is the 35mm (RUF) spacers. I can't see that being the issue, but could the spacers be putting the wheels out of balance? I'm going to get the wheels balanced tomorrow.
Does anyone have any ideas what the vibration could be, and when the wheels are balanced do they do them with the spacers?
Thanks,
Scott
Stock
RUFs
Thanks,
Scott
Wheels look great! I still go to the dealership (the only times), and pay the crazy money, to have my tires properly road forced balanced, and knowing they have the deep-pockets incase they ever marked up my wheels.
Glad you made it home safe and sound Scott! As I said on the phone, my car was a smooth as silk with those wheels on it...so much so that even my wife commented on it a few weeks ago on a drive home from picking up a pizza. If you aren't happy with them, we will be in Ottawa in November, so we can pick up the wheels and I will refund your money. To be honest, I am having severe seller's remorse
Keep me posted on your November trip. I don't think you will be taking the wheels with you, but it would be nice to get together again.
Thanks again for all your help yesterday,
Scott.
Thanks Mark. The only thing I can think of is we mixed the wheels up left/right when we mounted them on my car. I'm going to swap them and see if it solves the vibration. If not, I'll get them re-balanced using the road forced method to see if the shop can figure it out.
I would first rebalance the front Ruf wheels. If there is still a vibration, replace your front control arm bushings. I used to have the same problem and it was fixed by changing the bushings. Much written about this on the 993 forum. Good luck
Thanks the advice,
Scott.
Scott passed by my area before proceeding to meet Onami in Oakville for the RUFs and I checked his stock wheels (which I purchased and picked up from Onami in Oakville yesterday). So I took some iphone pictures and my car was dirty after being rained on the other day:
Ooo, I like that last pic Danny.
To answer the original question, the spacers don't cause any vibration issues on my car. I purchased my wheels/spacers new when I installed on my car.
Back to the fron CA bushings, these wheels are heavy and the additional weight could be a factor on the old bushings in your car. Just a thought.
Former Vendor
35mm is an awfully big spacer. It's probably an adapter. Check to see if they have a pilot on them for the wheels to sit on while being tightened. That should help center them while being tightened.
I'm scheduled for a road forced balance on Wednesday as Bradford suggested. If that doesn't fix the issue, I'll look at getting a set of Walrod bushings as replacements.
Scott.
