993 Turbo Forum 1995-1998
Post pics of your 993tt
Old 03-20-2008, 07:27 PM
  #121
ca993twin
ca993twin's Avatar
Vincent,
I'm not sure that you can't do this with the original (or aftermarket) mufflers in their original position... its been so long since I've seen a TT with mufflers I'm not sure. But... if you can make a 90 degree bend after the muffler toward the center of the car, you can then run short straight tube to the center, and then a simple 90 degree to the tips. I'm just not sure if there is enuff room after the muffler to make that first 90. Keep in mind that the Ruf bumpers are a bit "longer" than stock, and need a longer exhaust tip to get out nto the opening. So there may be more room than you can see with your stock bumper.
Old 03-23-2008, 02:22 PM
  #122
bb993tt
bb993tt's Avatar
Originally Posted by ca993twin
Here's the story I've been able to piece together. One of the very first Turbo R conversions was done using that CTR-2 center exhaust bumper and the CTR-2 exhaust. For some reason (cost? complexity?) they only did that on one car...
I enquired about this at Ruf DE. Was told that they stopped offering these because they were too expensive and too noisy.
Old 03-23-2008, 06:07 PM
  #123
Bradford
Bradford's Avatar
Too expensive I can understand but not too noisy. The center exhaust cars used the Ruf mufflers and just re-routed the pipe out the center instead of the sides.
Old 03-23-2008, 06:50 PM
  #124
bb993tt
bb993tt's Avatar
I'm just telling you what I was told. I dropped the subject purely because of the "too noisy" comment. I was already having problems passing the noise test all UK tracks enforce with my Andial mufflers. Even on 105 db days I've had problems. I've been warned a lot at one track and black-flagged for noise at another. Getting on tracks here, and staying there the whole day, was just more important to me than this mod.
Old 03-23-2008, 06:55 PM
  #125
djimenez993tt
djimenez993tt's Avatar
Default noisier
The reason ruf CTR and/or turbo r's with center exhaust are noiser is due to their external wastegate turbo setup. Those things scream like mean lemans style racers. In all honesty, I wish my car had external wastegates.
Old 03-24-2008, 08:32 AM
  #126
nicu
nicu's Avatar
fully agree with the external wastegate to noise relation.
from within the car though,the whisteling noise of the opening wastegate can get annoying at times....
Old 03-25-2008, 12:34 AM
  #127
hiflexaust
hiflexaust's Avatar
Default Yep....that'll work!
This madness must stop.
hahahahahahahaha.......yep Steve, I agree. I promise to stop spending three times my annual income on my 993TT if all you guys agree to do the same....I also promise to stop modding it and never, ever look for that elusive last HP that we all know is hiding down there under the dip stick somewhere.....so, is everyone with me???????
Old 04-12-2008, 05:45 PM
  #128
eclou
eclou's Avatar
Received 1,156 Likes on 571 Posts
Tried on some new shoes today. PES/Champion GP7 in 19x8 and 19x11. Front weight is only 18# rear is about 22#.
Old 04-12-2008, 05:58 PM
  #129
ca993twin
ca993twin's Avatar
eclou,
Those wheels look nice and their lightweight is a plus. I hate to say this, however... your big reds now look a bit on the small side now. See? The madness never stops!
What size/brand tire did you use?
Old 04-12-2008, 06:15 PM
  #130
sfbanchs
sfbanchs's Avatar
those wheels look awesome
Old 04-12-2008, 07:49 PM
  #131
Barney1
Barney1's Avatar
Nice..
Old 04-13-2008, 12:39 AM
  #132
eclou
eclou's Avatar
Right now I am using stock 997 sizes - 235/35/19 front and 305/30/19 rear. The F/R ratio is about 4% off from stock which worries me. I will be changing the fronts to 245/35/19 which will correct the ratio to 3% off from stock, which I hope is within tolerances. Tires are Michelin PS2's
Old 04-13-2008, 01:23 AM
  #133
sfbanchs
sfbanchs's Avatar
Can you elaborate on this because i am running stock 997 sizes as well does this translate into loss of performance?
Old 04-13-2008, 01:32 AM
  #134
ca993twin
ca993twin's Avatar
Sebastian,
eclou is stating that the tires have a 4% different rolling diameter, front to rear, with the fronts spinning about 4% faster than the rears. The question is raised... what does this do to the viscous coupler, which may like the tires having less of a difference. I have "heard" that 5% is the max tolerable, but have never heard what the ideal difference is (is it 0%?). Having too great a difference can lead to premature wear of the coupler.
But he also says that this is 4% different than the stock size. This is NOT correct. These tires are both quite a bit "taller" than the stock (18") size. This raises the center of gravity a tiny bit, and THAT may negatively affect the handling. My tires are 255x30x19 and 315x25x19, and these have a very small difference, front to rear, and both are also about the same overall diameter as the stock 18" tires.
Old 04-13-2008, 02:19 AM
  #135
eclou
eclou's Avatar
Steve 4% is not the difference in height, just difference in ratio F:R from stock. The ratio is what stresses the diff. The marginal increase in ride height I can adjust with the coilovers. I just don't want to kill the diff
Quick Reply: Post pics of your 993tt
