*** Intercooler Hoses Popping off ***
#61
I'm Still Jenny
I'm about to replace my hoses with MY '97 versions and some breeze clamps, what is involved in getting to the turbo outlet connection? I assume at least rear bumper and mufflers, but what else?
Thanks.
Thanks.
#62
I got told its the rear bumper and the mufflers (have not attempted mine yet) but I dont have mufflers on as I have the fabspeed bypass tubes.
there is a picture in one of the previous pages (page 4 i think) showing access to the top joint on the turbo.
#63
Rennlist Lifetime Member
There's no need to remove the bumper to get the lower hose connection. But if you're going to mod the sheet metal to make room for the breeze clamps you'll probably ant to remove the bumper and the muffler support brackets.
I suspect the lower connections aren't in need of better clamps as much as the upper connections are. This is probably because of the smaller diameter of the hose and the support offered by the nearby sheet metal.
#65
#66
Interesting, mine fit fine without modiying the sheet metal. If you look at the pic I posted, the sheet metal has not been altered.
#68
This has just happeend to me! 400 miles after owning the car, the hose split off at the jubilee clip end, mangleing the top of it so I cant use it again.
I have just ordered the High Torque Jubilee Clips, shall I just order a Hose from Porsche? the standard 408HP one, or shall I get the X50 one - will they fit.
Does anyone have any instructions on how to change the hose, Can I do it myself?
thanks in advance
thanks in advance
#69
Porsche only sells one hose for the 993tt and it's a pricey one. You can do it yourself, just arm yourself with a full array of expletives! Job is much easier if you remove the rear bumper and mufflers.
#70
#71
>98C4S
Try Suncoast Porsche in Sarasota for the hoses - they have good prices on P parts.
T bolt clamps help a lot.
I blew one last year with same outcome - torn at IC connection.
Good luck.
Good luck.
#72
Thanks for the responses guys, I am based in the UK - London, so I think I am stuck with OPC's to get the parts. I have ordered some High Torque Jubilee clips so I will use them.
Does anyone have any instructions on how to do this without taking the bumper or Mufflers off?
Pics would be great too!
Thanks again
Thanks again
#73
It's pretty straight forward, just take the intercooler off and take a look at the space you have down by the turbos. You will need to take the wheels and mufflers off as a minimum. I've done it multiple times, but the space is limited... just be careful you don't drop anything into the turbo...
#74
OK, I'm resurrecting this old thread...did anyone ever find another source for the hard intercooler pipes that were previously sold by MindOverMotorsports and Huntley Racing?
Thanks in advance!
David
Thanks in advance!
David
#75
Lifting an old thread. The right hose to the intercooler came loose during a track day two weeks ago. It has happened once before that it came loose. That time it was on the end closest to the intercooler. After that I changed both hoses with new OEM ones. It was two years ago. When they were changed, I was informed that the fit was not perfect on the right side. So this time it came off at the other end closest to the turbo. I was not surprised when the Porsche workshop called me today to give me an update what had happened.
The car was not drivable so I had to call a tow truck two weeks ago. Had to take a flight home. The course was located at a remote location on an island. This is something I do not want to encounter again.
Searched the forums and saw that it is not uncommon for the right hose comes loose. Is it just not my car that the fit is not perfect? Is the solution to replace the hose clamps? If that is the case where can I buy the clamps mentioned in this thread in Europe?
Could it be that it is possible to adjust the turbo and intercooler to fit better on the right side? The dealer that has the car right now said that they where not totally happy with the fit. This could happened again. They want to order a new hose (the old one is two years old). This won't change a thing. And I don´t know if it´s worth to let them spend hours to adjust the turbo or the intercooler if they somehow is not fitted right.
Any comments?
Any comments?
