993 Forum 1995-1998
PSS10 Settings Question
Old 04-08-2017, 10:59 AM
  #46
Tlaloc75
Tlaloc75's Avatar
How much does this depend on tire construction? Is there much variation across brands and types or do you feel that rule of thumb works regardless of tire?
Old 04-08-2017, 11:10 AM
  #47
mikemessi
mikemessi's Avatar
I've run Bridgestones, Michelins, and Falken. Same rule of thumb for all. The Michelins have the softest sidewall and are much more sensitive to pressure than the others but in my experience were all best in the same ranges. The Bridgestones had the hardest sidewall and least pressure sensitivity but were also the harshest ride.
Old 04-08-2017, 11:13 AM
  #48
Tlaloc75
Tlaloc75's Avatar
You are a wealth of knowledge - thank you
Old 04-08-2017, 11:16 AM
  #49
mikemessi
mikemessi's Avatar
Oh I've had Pirelli p zeros too and they fell in the middle regarding sidewall stiffness. These were the first generation p zeros. I've heard the new ones are different but not sure how.
Old 04-08-2017, 11:26 AM
  #50
mikemessi
mikemessi's Avatar
This is highly subjective and I'm sure someone will disagree but I prefer soft sidewalls for the street for a softer ride and the ability to change that with tire pressures. For my DE track days I run a stiffer sidewall. Track days get busy and the consistency of the Bridgestone RE11 or RE71 is really nice. I think the stiffer sidewall also works better on track with stock camber settings. Without negative camber soft sidewalls really roll over.
Old 09-20-2022, 04:45 PM
  #51
vancouver z
vancouver z's Avatar
Originally Posted by Tlaloc75
I've been experimenting with various PSS10 settings and I had a strange experience today. Recently, I've been running them at 5/6, with my tire pressure at 34/38. I decided to bump up the rear in order to see how it felt, so I stopped mid-drive and changed the settings to 5/7.
The result was interesting. The back of the car felt more solid and controlled in its motions but the front of the car did not do what I expected. I was expecting more grip in front and what I experienced was less. The rear felt more planted and the front felt like it had less traction, wanting to push wide on corners.
What's going on here? I expected the rear to get looser and the front to dig in harder, but the opposite is what happened.
Next I'm going to try upping my front tire pressure 2lbs, so I'll be at 36/38 with the shocks still at 5/7 and then I'll try PSS10 settings of 6/7 and finally back to 5/6.
I assume others have been through this process. Did you have a similar experience?
Is it easy to reach around the tire and rotate the collar or is best done with the wheel off? is there a particular way to face the shock to make access easier? like facing inwards or facing outwards? thanks and sorry to open an old thread.
Old 09-20-2022, 06:34 PM
  #52
71-3.0-911
71-3.0-911's Avatar
This is not possible, but ripe for jokes...
Remove tire, adjust with spanners, replace tire. Easy day.
Old 09-21-2022, 12:16 AM
  #53
wesr
wesr's Avatar
I can adjust mine by turning the front wheels to gain access. Rears you have to lay down and reach into the wheel well with a partial look at the adjustment ****. Be careful of the mufflers if the car’s been running. Easy to get burned.
Old 09-21-2022, 04:20 AM
  #54
911PERVY
911PERVY's Avatar
Easy enough to adjust without taking wheels off or jacking up, a torch and a mirror help until you get the hang on it
ronnie993tt (09-25-2022)
Old 09-21-2022, 08:51 AM
  #55
71-3.0-911
71-3.0-911's Avatar
Are you taking about the ride setting or the ride height. When he mentioned collars, I assumed ride height. I don't see how it's possible to adjust ride height collars with the wheels on. Simply no room.
Old 09-21-2022, 08:55 AM
  #56
911PERVY
911PERVY's Avatar
Of course I mean adjust settings on the knurled ****, no way you can alter the height with the car on the ground
Old 09-24-2022, 07:02 PM
  #57
FLYT993
FLYT993's Avatar
been running 6/7 for the last 3 years. goes where i point it, and absorbs bumps pretty nicely.
Old 09-25-2022, 04:41 PM
  #58
ronnie993tt
ronnie993tt's Avatar
4/6 on the Turbo's PSS10's with N3 rated PS2's @ 36/40. I think they purposely resurface the roads with potholes! I would prefer 6/8.
Quick Reply: PSS10 Settings Question
