Condensation in 993 Engine
AFAIK Porsche oil is repackaged Castrol Edge 10w-60
It fails on 2 counts
1) for 993 summer use 15w-40 or 15w-50 are the recommended summer weights(look in you owners manual)
2) ZDDP specs back in the mid '90's was ~1100ppm P & 1400ppm Zn, I know of no Castrol product that even comes close to those levels
It's partially due to Cafe requirements but more to the EPA mandating long life emissions systems, ZDDP kills catalytic converters, so API came out w/ the new ILSAC standards that killed 2 birds w/ one stone, Most modern engines run fine w/ these low weight low ZDDP starburst label oils, 993 do not, or I should say that will run but will also wear out much faster.
When I had a climate control unit fan speed surge issue I found this post by rennlister RecardoD on the 964 section. I believe that there have been other diy's on Rennlist and Tore's ( https://www.bergvillfx.com ) website you might also want to read.
https://rennlist.com/forums/964-foru...aning-diy.html
I used his instructions to clean the thermistor and used electronic contact cleaner on connections and fan and temp rheostats. I didn't need to replace the thermistor fan so I skipped that part.
Fan speeds have been working correctly for 6 months now!
[QUOTE=Your A/C problem sounds like a bad temp sensor in the CCU, climate control unit. The dealer will be able to pull codes with there hammer tool and know exactly what is wrong. Could also be a bad resistor on the rear engine fan.[/QUOTE]
I took it to the dealer because one would assume they would be able to read the codes. They found no codes. And, the a/c has been working flawlessly since the day that it went haywire. It figures.
As for the milky oil—thanks to all who commented. I didn't check the filler cap before Thursday's oil & filter change. But, did just now and underside of cap is perfectly clean.
Will have a couple of long drives in next month including the 600-mile R/T to Werks Reunion. I know that it needs more of that, and less of the local short-trips.
Sounds like it's just atmospheric water condensation in the sump that occurs when you have a temperature differential with a warm engine that is run for very short intervals and then left in a cold environment overnight. Usually not an issue if it's a small amount of moisture, you just need to run the engine for extended period of time to get the oil to ~200 degrees (F) to dissipate the moisture.
Oil change, analysis, and monitoring of water over time, longer running times, and an operating temperature check.
Selling oil:
Please show us where this is documented
https://www.pca.org/news/2015-03-12/...d-tech-tactics
http://www.porsche.com/usa/accessori.../motoroil-faq/
