Glass face for Speedo?
I just called North Hollywood Speedo, they say they replace speedo face with acrylic lens, not glass, because of reset **** hole. I thought some members said they got glass? Clarification please. Does anyone make a glass one?
Thanks as always.
Thanks as always.
Are the original ones glass?
When I called NH Speedo a few months ago when replacing my broken odometer gear, my understanding was that their supplier quit making the glass version due to problems with the hole. Frankly, my original one still looks great after 20 years so I left it in. I would think an acrylic one will be fine too.
Seared
Might want to contact these guys and discuss:
http://www.heiler-tachodesign.de/Com...3#.WId5GvkrKUk
Technical Guru
It shouldn't be a problem to have a local shop cut and drill the glass with a waterjet and then temper it, probably cheaper too. I've had it done with 19mm sheets of OptiWhite.
Thanks as always.
Thanks as always.
In the meantime I had successfully drilled the first glass that I still have laying around.
Anyhow, the original acrylic lens is easily scratched with swirl marks from cleaning, so if someone is replacing the gear that would have been a good time to replace. It looks much much better matching the other 4.
