Rennline Cell Phone Holder Install w/pics
Even works for a RHD, actually you can mount it either side, but I like it on the door side. Small, hardly notice it, best mount I have owned. Others are now in the tip!
Just started to order one but international shipping will cost $62 USD. Yikes.
I see there is an Aussie equivalent https://shopmate.auspost.com.au
I just installed the rennline mount and it is perfect. One problem, on my 1995 993 the clock has one large multi-pin connector that disconnected without much trouble but it also has a single wire connector that would not disconnect. In the course of trying to remove it the wire pulled off the connector. The clock and all the indicator lights work fine. The wire appears to connect the tiny rocker switch used to change the time. That is not functioning now. Does anyone know how this connector comes off so I can solder the wire back on? Should I just pull harder?
This might be too neurotic, but... for those mounting the steel plate on the inside of their phone cases or directly to their phones I put a small piece of clear bra between the phone and the plate to make removal easier and prevent the plate from scratching the phone.
+1. Never to neurotic. "The devil is in the details".
New car delivery is often accompanied with a protective film (blue) covering bright work etc., from damage/scratches. Door sill plates, trunk sill plates to name a few as example.
Here's neurotic... The Frau's MY05 Subaru Outback XT now ten years on from order/delivery... continues to wear the protective blue film on the aluminum door sills and the rear hatch aluminum sill plate. The Outback XT has that pre-delivery look at age 10....
This Rennline mount is the perfect design solution for a Cell phone or even a Garmin Nav. I like it!
My question would be if the mount could be rotated closer to the 2 hour mark not touching the dash so to not block the vent as much. I'd like to see a side shot of the space between the dash and the mount, is it close to touching at the 3 hour mark?
Here's my solution
I would not recommend to mount anything on the airbag covers. This is potentially very dangerous, there's a risk of the object being shot towards the passenger if the airbag deploys. There's also risk of obstruction of correct airbag deployment.
Cheers,
Tore
Cheers,
Tore
+993 same thought!
