993 Forum 1995-1998
HVAC Unit dead - trouble shooting check list
Old 08-24-2016, 09:27 PM
Heidi993
Heidi993's Avatar
Default HVAC Unit dead - trouble shooting check list
Hi all, no life at all in the unit.
No lights on the demist button, no blower, nothing.
Unit just seems dead.
Would anyone have a step by step fault finding process please.
The air con has never worked, and was aware of this when I bought the car. The seller said at the time that they are very problematic. The heater and demist always worked really well.
Just an aside, the front of the unit looks slightly different to all the ones I have seen images of on the internet while researching the problem.
Thank you 😘
Old 08-24-2016, 09:49 PM
Railmaster.
Railmaster.'s Avatar
Bervill FX have a step by step guide on their home page, the unit is called CCU if You want to do a search here!
Old 08-25-2016, 04:47 AM
ToreB
ToreB's Avatar
Thanks for the reference Railmaster.
Heidi, check fuses 1, 28 and 17. How is your CCU different from others? Any pictures?
Cheers,
Tore
Old 08-25-2016, 08:49 AM
Railmaster.
Are You sure that Your car have an AC? Maybe it doesn't and that could be the reason Your HVAC unit looks different! Or it could be a unit for a car without AC.
Old 08-25-2016, 12:38 PM
Heidi993
Heidi993's Avatar
Thanks for the quick replies,
I shall post a photo of the unit soon as I get home, it's raining here and even if I wanted to take her out, it's too difficult driving when I can't stop the windows steaming up!!!
Old 08-25-2016, 12:43 PM
Heidi993
Heidi993's Avatar
Cheers,
Tore
Are these fuses all under the bonnet in the same place (or hood or whatever it's called depending where you're from)?
I mean like in the footwell etc???
Old 08-25-2016, 02:20 PM
Railmaster.
Take a picture of Your engine bay aswell so We can see if there is an AC compressor installed! The fusebox is located in the front luggage compartment.
Old 08-25-2016, 05:01 PM
ToreB
ToreB's Avatar
All the mentioned fuses are in the main fuse box in the luggage compartment.
Cheers,
Tore
Old 08-26-2016, 03:16 PM
Heidi993
Heidi993's Avatar
Ok this is the unit, and looking at it I would say it doesn't have air con.
I just assumed it had air con as the guy who sold it specifically said it wasn't working????
Old 08-26-2016, 03:17 PM
Heidi993
Heidi993's Avatar
Also checked the 3 fuses, in fact all the fuses
Old 08-26-2016, 04:53 PM
ToreB
ToreB's Avatar
This is a normal non-A/C Climate Control Unit.
If all fuses are OK, you have to start digging with a voltmeter to find out if all the power supplies are present on the CCU harness connectors. You'll need some electric skills to do this. If all power feeds are OK, there's probably an internal fault in the unit, which is no problem to fix.
Cheers,
Tore
Old 08-26-2016, 05:30 PM
pp000830
pp000830's Avatar
Received 1,444 Likes on 1,017 Posts
I thought the car had A/C, is there a compressor on the engine? Is the CCU original?
Old 08-26-2016, 06:04 PM
Railmaster.
As I said! Show us the engine!
Quick Reply: HVAC Unit dead - trouble shooting check list
