993 Forum 1995-1998
CV Boots
Old 08-24-2016, 07:05 PM
pp000830
pp000830's Avatar
Received 1,444 Likes on 1,017 Posts
Default CV Boots
Two of the CV boots on my car bit the dust. Decided since I do not have a lift and its is a time consuming messy job I'll leave it to the professionals. I ended up at the dealer for the work. Estimated hours and parts cost to repack and replace all 4 seems reasonable, labor rate is high but at least the guys are strait shooters when dealing with me. Something I have found to be hard to find at times in these parts.
Old 08-24-2016, 07:53 PM
NYC993
NYC993's Avatar
And the point is....? At least tell us what the cost is at dealer.
Some repack with high temp grease to prevent melting the grease and have it start leaking out via vent tube.
Old 08-24-2016, 08:28 PM
Pichu
Pichu's Avatar
I think the point is sometimes it's better to leave the greasy stuff to the dealer. But I LOVE this type of greasy repair. Very satisfying. I'm going to do the CV's on my 993 as well.
Is there another 'while you are in there' repair to be done? I will probably wind up cleaning the whole rear end. Time to change Avatar pic, 964 gone
Old 08-24-2016, 08:38 PM
AZ Targa
AZ Targa's Avatar
Did mine in my garage while on jack stands. It's easy, just time consuming, and a little messy.
Just saying it can be done at home, that is if you want to do it.
Old 08-24-2016, 08:39 PM
nine9six
nine9six's Avatar
The learning and experience is priceless...I was awestruck at the engineering design of the CV joint. Just brilliant!
Old 08-24-2016, 10:17 PM
AOW162435
Seared
AOW162435's Avatar
I've done the work with a fellow Rennlister. Messy, but certainly doable at home.
Andreas
Old 08-25-2016, 12:02 AM
NP993
NP993's Avatar
This already pointless story was rendered even more pointless by the absence of the only information that the reader could use -- numbers and prices.
Old 08-25-2016, 12:42 AM
Pichu
Pichu's Avatar
^ Too harsh!!
Info; 4 hours x shop rate labour + parts. From Pelican it's $109 for all boots, grease, bolts.
Plus literally billions of useless posts (ie complaining about useless posts is pretty useless).
Old 08-25-2016, 01:30 AM
vincer77
vincer77's Avatar
I did these during my engine tranny drop and it was the worse, messiest part of the project. Not hard, just messy and frustrating.
I did all 4 boots. The first one was tricky. The second one easier. The third one even easier. I figured the 4th one would be a breeze. For some reason it was the hardest and most frustrating.
Old 08-25-2016, 08:28 AM
pp000830
pp000830's Avatar
8 hours, Total quote $1200. Probably paying a $400 premium via labor rate. Dealer implied it may cost a little less.
Old 08-25-2016, 09:12 AM
Quadcammer
Quadcammer's Avatar
Received 1,368 Likes on 792 Posts
$1200? wow, I do not in any way consider that fair.
I'm surprised you didn't just seal them up with black plumbers caulk from Home Depot
Old 08-25-2016, 09:16 AM
NYC993
NYC993's Avatar
Ouch, but that makes sense. Dealers usually charge double. Indy rate is usually 350-400 per axel in labor and parts.
Old 08-25-2016, 09:32 AM
pp000830
pp000830's Avatar
What sent me to the dealer was the local leading independent would not give me a quote for an alignment. He quoted his labor rate and said few cars accept an alignment without additional work and they take at a minimum a few hours, "few" meaning three or more but a low number, not a quote in my book. These type of statements make me feel like I'm being gamed as he did not give me a quote. The dealer gave me a reasonable quote for the alignment that was completed without incident and resolved my handling issue. While on the rack the technician pointed out two torn boots which resulted in my agreeing to the follow-on work. The independent lost $1400 total work because I feel he mishandled his interaction with me.
Old 08-25-2016, 09:39 AM
pp000830
pp000830's Avatar
Nah, May be 3M Electrical Mastic sealing tape will do the trick!
Old 08-25-2016, 10:02 AM
NYC993
NYC993's Avatar
That's consistent with my experience. It's hard to get a quote from Indy as they don't want to over promise and under deliver. Same job on 20 year old 993 can take 2 hours or 5 hours you don't know until you are there.
When my shop was doing an alignment a rear arm had bushing that torn inside so the arm had to be replaced.
Quick Reply: CV Boots
